Rough idle after PCV Autotune install - Road Glide Forums
post #1 of 5 (permalink) Old 05-03-2019, 10:20 PM Thread Starter
Hey guys,
So like an idiot i can’t leave well enough alone. I’ve been using a base map for awhile that was working pretty okay. But def felt i could get a little better. I got a really good deal on the auto tuner through a buddy that i couldn’t pass up.
Set up:
2013 FLTRX
2010 headers to eliminate CAT and conveniently right size for the AT O2 sensors
RC Components 4” slip ons
Arlen Ness Big Sucker
Stock Cams
Everything is for sure hooked up properly, and using the same base map prior to AT install
I added the auto tune, now the idle is horrible. It fluctuates between 800 and 1200 rpm, usually even shuts off after the first start up and i have to try again.
While riding it is a bit rougher too, pops that i never had before etc. But my biggest concern is the idle.
It does get better after warming up and running for a minute or so, but still worse than it ran before.
Any suggestions?
Thanks in advance
SwarleyManson62 is offline
post #2 of 5 (permalink) Old 05-04-2019, 04:27 AM
I have powervision, I used it to autotune both my rides.
I donít know abou PCV autotune, but with powervision autotune spark advance change because of the learning mode and the ride is little rough as well
Beaver is offline
post #3 of 5 (permalink) Old 05-04-2019, 07:22 AM
Dickie's Avatar
Possible bad 02 sensor? Here is a link for the manual if needed. Shows installation, configuration and how to check sensors. Had PCV with AT on my 2011.
http://www.powercommander.com/downlo...IAT-300.06.pdf
2017 FLTRU
Dickie is offline
post #4 of 5 (permalink) Old 05-04-2019, 04:34 PM
Did you save the map before auto tuning ? Maybe reload it to see if it corrects itself.
Big_gary is online now
post #5 of 5 (permalink) Old 05-26-2019, 09:56 AM
Skip Vargas's Avatar
Sounds like your still in AT mode. Did you get as much of the cells on the learn green screen filled and then hit exit, export learned and save to an empty slot, then disable AT and flash the new AT tune....
2019 ROAD GLIDE SPECIAL
Stage 11 Torque Cam
Skip Vargas is offline
Fullsac Install FWBRG Intake and Exhaust 7 10-25-2017 08:33 AM
Love Jugs Mighty Mite Install moto.rich Tech Area 4 07-24-2017 04:39 PM
Harley Ipod Interface not working after install. Cobal59 Audio 1 03-21-2017 02:42 PM
New 16 FM Jackpot-PV Install chriscalabro Fuel Moto 3 10-08-2016 11:43 PM
rough idle todd choops Troubleshooting for Road Glides 3 03-27-2012 08:36 AM
