M8 wideband module - Road Glide Forums
post #1 of 7 (permalink) Old 05-07-2019, 10:15 PM Thread Starter
BH#103's Avatar
M8 wideband module
Anyone utilizing the wideband tuning module on an M8? Noticeable difference or a waste of spare change?
"SLIVER"
BH#103 is offline
post #2 of 7 (permalink) Old 06-08-2019, 04:42 PM
Nazareth's Avatar
It depends on what you are trying to accomplish.
"Hair of the Dog"
Nazareth is offline
post #3 of 7 (permalink) Old 11-05-2019, 09:18 PM
I'm in the middle of adding fp3 wideband will update as I go
post #4 of 7 (permalink) Old 11-09-2019, 10:46 PM
Update I added the wide band fp3 today the difference in tuning is day and night from the regular fp3. Road about 40 miles all cells green I used to spend days on the regular fp3 now can actually set at good afr......I like
post #5 of 7 (permalink) Old 11-10-2019, 01:01 PM
woverby's Avatar
Send a message via Skype™ to woverby
Did you also need to install wide band O2 sensors with this upgrade? If yes (which I assume), did you do this when you installed new pipes? The reason I am asking is can you remove/replace the stock sensors after putting miles on your bike? I could not on my VROD.
2017 FLTRU
Colorado Springs, Colorado
woverby is offline
post #6 of 7 (permalink) Old 11-11-2019, 04:49 PM
I added cobra 2 into one pipes that have extra 18 mm bung. Was told by Vance and Hines if you only have one access take out narrow band tune then replace. This tuner tunes completely in a few minutes I'm very pleased
post #7 of 7 (permalink) Old 11-11-2019, 04:50 PM
The kit comes with Bosch wide band sensors
madmat likes this.
