Anyway to compare pcV maps? - Road Glide Forums
post #1 of 2 (permalink) Old 06-18-2013, 11:59 PM Thread Starter
bikerglasses's Avatar
I know pcIII had a way, but don't see anything in pcV....?
Ian -- Tucson, Arizona
- MGS True Duals, Ness Big Sucker, 12' Twin Peaks, -1" Monotubes
bikerglasses is offline
post #2 of 2 (permalink) Old 06-19-2013, 12:43 AM
Triplej's Avatar
Good question. I have never noticed before. You can compare maps on the PCIII and the PV but there seems to be no option on the PCV. I even tried to open 2 PCV windows but it won't even let you do that. When you try it gives you a warning that "this application is running. This instance will be terminated". You can open 2 windows in both the PCIII and PV and they both have the compare feature but not on the PCV.
Found this on the HDforums, maybe it will help.
http://www.hdforums.com/forum/tourin...ere-it-is.html
Triplej is offline
Compare Tail of the Dragon to the Devi'ls Highway 1st Sgt Road Trip Discussions/Stories/Pictures 10 07-31-2018 05:46 AM
Will there ever be a way to compare seats Chicago Harley Boy *General Road Glide Discussions/Pictures 5 09-04-2013 01:06 PM
pcv maps 08gezzer ECM/Fuel Management systems 0 11-18-2012 10:51 PM
Can anyone compare the Klock 8" with the NC Wave short? Emdog Windshields 1 04-05-2012 11:13 AM
PCV with 2 maps Sancho ECM/Fuel Management systems 4 04-05-2010 10:30 PM
