Oxygen sensors help - Road Glide Forums
post #1 of 18 (permalink) Old 06-20-2013, 07:28 AM Thread Starter
binkley2's Avatar
Cool Oxygen sensors help
I am somewhat confused. I am not sure if the person who sent me this info knows what he is talking about, but he now has me concerned. I removed the cat from my stock exhaust header. My motor is otherwise bone stock except I am running cobra slip ons. I have not done the stage one nor am I running a tuner. After I did the cat removal I had two occassions where the bike refused to run after I turned it off then immediately tried to turn it back on. It appears it got hot and went into limp mode, one of the times I held the throttle open and it did start but only ran on one cylinder. Both times I was riding a road along a river at less than 25 MPH for several miles. Once I allowed the bike to sit for about 5 minutes it started and ran fine. So I posted this to see if the cat removal could cause it to run hot. I got a response telling me to make sure I put the right oxygen sensor in the right hole. He told me grey to the front and black to the rear. The problem I have is the wires on both sensors have the same colored wires (I think, its hard to get in there), and I dont see any other colored marking on them although they are hard to get to. Does this make any sense to anyone and if so, can this cause an overheating issue? And if so, how do you tell which is which? I have a very long ride this weekend with a large group and really dont want any issues with my bike. By the way it is a 2011 RGU with 7000 miles and I do have my lowers on. Any help is greatly appreciated.
BEER!
2011 Road Glide Ultra, 16" HCC apehangers, custom vivid black and limetime green paint, Cobra slip ons. Much, much more to come
Texas proud, and yes, I do believe in the 2nd amendment!
binkley2 is offline
post #2 of 18 (permalink) Old 06-20-2013, 07:45 AM
RaJaH's Avatar
My guess would have been the O2 sensors in the wrong hole also if as you said there have been no other mods made. I have had no issues since removing my cat and like yours mine is bone stock except for the slip-ons.
Sorry I can't add any other insight except maybe disconnecting the negative battery cable and then re-attaching it to see if the ECM re-sets.
2011 FLTRU
Lost Count of the Accessories
RaJaH is offline
post #3 of 18 (permalink) Old 06-20-2013, 08:13 AM
MikeMan's Avatar
The sensors have the same color connectors, but the connectors on the bike's wiring harness are different colors. I don't remember if they are located under the seat or the right side cover. Mine are under the right side cover now, but I don't remember if that's where they were before I added the wide band sensors.
2010 FLTRX
MikeMan is offline
post #4 of 18 (permalink) Old 06-20-2013, 08:19 AM
mocotom's Avatar
If the O2 sensors were hooked up incorrectly the bike will have issues with the way it runs all the time. From your description of the problem your experiencing, it sounds like the motor is overheating and going into limp mode. I know this sounds like a broken record, but most times any change in exhaust and or intake on the new bikes needs to be addressed with some type of fuel adjustment. Especially in hot climates such as Texas.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #5 of 18 (permalink) Old 06-20-2013, 08:25 AM
PGR
PGR's Avatar
The connectors under the right side cover are color coded. Make sure they are plugged in correctly and FULLY plugged in. Then trace the wires to the sensors and make sure they are plugged into the correct holes. The holes are marked "G" and "B" for grey and black.
Ron..........................
PGR is offline
post #6 of 18 (permalink) Old 06-20-2013, 10:20 AM
rageglide's Avatar
Make sure the wires to the sensors have room to flex and aren't tight or hung up on anything. As PGR said, the actual connectors are color coded and in plain sight under the right side cover. The head pipe has an 'F' and an 'R' next to the bungs.
2012 fltrx
rageglide is offline
post #7 of 18 (permalink) Old 06-20-2013, 11:47 AM
another factor that I have read with removing the cat is crosstalk between the two sensors
2013 RGU, black of course....
y2kflhr is offline
post #8 of 18 (permalink) Old 06-20-2013, 12:33 PM
PGR
PGR's Avatar
Urban legend...... If you open up the pipe, the sensors are ahead of the cat. Removing the cat does not affect the sensors in any way. They are also separated by the tube, as seen in this picture.
The sensors are being played by sharpies in this post catectomy pipe. As you can see, there is no way they could talk to each other.
PGR is offline
post #9 of 18 (permalink) Old 06-20-2013, 01:42 PM
rageglide's Avatar
I would not say there's no way, because reversion stirs things up pretty good... But I would say it's unlikely much different than when the CAT was there.
Certainly wouldn't expect cross talk to be creating the issue the OP has encountered.
2012 fltrx
post #10 of 18 (permalink) Old 06-20-2013, 02:18 PM
PGR
PGR's Avatar
If you have enough reversion to mix gasses from one tube to the other, you are running serious high lift cams. In that case running decatted stock pipes would be kind of defeating the purpose of spending the money on cams..
And you are right.... it would be no different than when the cat was still there. But if there was a difference, you would think that not having anything in the way of the outflow, with the cat gone, would create LESS cross talk.
PGR is offline
oem oxygen sensors locokk64 Wanted! (Buy or Trade) 6 10-24-2016 08:18 AM
oxygen sensors locokk64 ECM/Fuel Management systems 0 10-23-2016 08:35 PM
Oxygen Sensors faststan Intake and Exhaust 11 07-05-2016 05:32 PM
Oxygen Sensors jonneeu Intake and Exhaust 3 01-09-2014 07:06 PM
Oxygen sensor something to know?? black-glide Troubleshooting for Road Glides 2 01-08-2011 02:28 PM
