Autotune - Road Glide Forums
post #1 of 8 (permalink) Old 06-23-2013, 05:42 AM Thread Starter
longrides's Avatar
Autotune
Finally got the gutted head pipe installed from B&E, re-cored mufflers from B&E, and FM Air kit. Nice rumble.... still smells a little from the ceramic coating curing on the head pipe. Installed the Power vision and map from Fuel Moto. No lag, no popping and frankly, didn't notice a lot of difference until..... I had to get on it to get around a vehicle to catch an on ramp....
HOLY $H!T the bike almost came out from under me!
The map seems to be spot on. Checked the plugs and they are a nice light tan.... no more ash white as with the OEM setup.
However, given my long history of tinkering and not leaving well enough alone.... I decided to try Auto Tune to see if I could tweak it a bit and I keep getting a error message... cannot communicate with the ECU or something. The lead is routed under the tank and neatly to the data port under the left side panel. I've watched the video a couple of times and will try again today.
I upgraded the firmware to the latest and the map did load .... just can't figure why autotune won't run. Since I can't reach FM or dynojet today I thought maybe the experts here may have a suggestion.....
Currently Bikeless
Shopping for a '15 or '16 found one and it aint HD
2013 FLTRX Black Denim - 4" ceramic Jackpots, Fullsac X pipe header, PV w/FM map - gone but not forgotten
2008 Anniversary Edition,
gone but not forgotten.
longrides is offline
post #2 of 8 (permalink) Old 06-23-2013, 06:33 AM
JJSW1283's Avatar
At what point does it show the error message?
JJSW1283 is offline
post #3 of 8 (permalink) Old 06-23-2013, 06:51 AM
tdkkart's Avatar
Ignition on, and the kill switch has to be in the run posiition.
tdkkart is online now
post #4 of 8 (permalink) Old 06-23-2013, 07:12 AM Thread Starter
longrides's Avatar
As I recall, I think the bike was idling.... I'm going to try again this morning.....
Currently Bikeless
post #5 of 8 (permalink) Old 06-23-2013, 07:26 AM
pat123's Avatar
Don't do it while the engine is running you will damage the computer. Do it key on engine off.
pat123 is offline
post #6 of 8 (permalink) Old 06-23-2013, 07:27 AM
mocotom's Avatar
The PV can't read the ECM while the motor is running. Just turn key on, kill switch to run position. Then follow the steps in the book or on their video.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #7 of 8 (permalink) Old 06-23-2013, 09:38 AM
smitty901's Avatar
Watch it take notes go for it
http://blogs.dynojet.com/index.php/2...ideo-tutorial/
smitty901 is offline
post #8 of 8 (permalink) Old 06-23-2013, 04:55 PM Thread Starter
longrides's Avatar
Worked fine today.... don't know what I did wrong last night..... Thanks for all the advice.
Currently Bikeless
PCV Autotune 615McCord ECM/Fuel Management systems 3 11-26-2011 08:42 PM
PCV AutoTune full exhaust and stage 1 filter 615McCord Road Glide Specific Discussions 1 11-13-2011 07:20 PM
AutoTune, worth the $? Gonekat ECM/Fuel Management systems 4 04-24-2011 10:18 PM
Power Commander 5 With Autotune Modules works with all 96's Garcou Classifieds Archive (3 months old+) 4 01-10-2011 11:12 AM
Stock ECU & VH Fuelpak vs T-Max Autotune DAK47 ECM/Fuel Management systems 3 12-03-2010 09:48 PM
