Mount or no mount for PV - Road Glide Forums
post #1 of 15 (permalink) Old 07-02-2013, 03:57 PM Thread Starter
I just installed my PV but did not buy the mounting kit. Now Im wondering if I should or not??? My first thought was to much clutter on the bars but this thing looks pretty neat!! What are you guys doing with it? Thanks
Boxercop is offline
post #2 of 15 (permalink) Old 07-02-2013, 04:05 PM
RhinoHD's Avatar
I have mine mounted and its worthless in the sun... Even with the little visor...
Life is good but it's not easy!
RhinoHD is offline
post #3 of 15 (permalink) Old 07-02-2013, 04:21 PM
Torquey's Avatar
If I had one, I'd squeeze it in on the bars. Just about all displays are worthless in the sun, but when there's no glare, there's cool factor. In the PV5 case, there's also the possibility of immediate, on fuss adjustments.
Torquey is offline
post #4 of 15 (permalink) Old 07-02-2013, 04:23 PM
elbohead's Avatar
I have mine mounted and use it all the time to monitor engine temp. I like that you can set it up with multiple gauges (many to choose from) as well as night and day time color contrast. DinoJet recently added a video showing how to set up the gauges.
http://www.dynojet.com/Powervision/p...on-videos.aspx
I also bought an inexpensive handlebar mount that works great. I can remove the PV quickly when I'm not riding and can also rotate it in any direction to improve visibility while riding.
2012 FLTRX, BBP, 13" MadStad, Fuel Moto Pro Billet AC and 4" Dyno Tuned Jackpots, catless header, DinoJet Power Vision, Horizon Helibars, Iron Aces mount, HD Aileron grips, Ward's cooling fans, Mustang Wide Tripper solo, CD Plasma Rods and LED turns...
elbohead is offline
post #5 of 15 (permalink) Old 07-02-2013, 04:58 PM
OKBigD's Avatar
I flashed my ECM and then disconnected the PV.. My bars are 1.5" and the mount that came with it won't work.... I'm not sure I'd like the clutter either....
Has anyone mounted it to the highway bar just below the tank? Just a thought....
OKBigD is offline
post #6 of 15 (permalink) Old 07-02-2013, 05:04 PM
tdkkart's Avatar
Mine's permanantly mounted to the bars just below and left of the speedo, the mount that Fuel Moto sold with it allows it to tuck in nice and tight.
I set mine up with the "nighttime" gauge background, black with white numbers, seldom have trouble seeing it while riding.
The PV has way to many neat features and usefulness to leave it laying on the bench.
tdkkart is offline
post #7 of 15 (permalink) Old 07-02-2013, 06:49 PM
Harley06's Avatar
I was not going to mount mine. I saw the video on how to set the gauges and thought how cool that would be to use on a long trip. I am leaving for Ten. Thursday. Its mounted and ready to go.
Harley06 is offline
post #8 of 15 (permalink) Old 07-03-2013, 09:15 AM Thread Starter
Kind of what I thought after getting it......Do you use it often or just nice to have it in case?
Boxercop is offline
post #9 of 15 (permalink) Old 07-03-2013, 09:16 AM Thread Starter
Would like to hear your thoughts after using it on a trip......
Boxercop is offline
post #10 of 15 (permalink) Old 07-03-2013, 09:26 AM
tdkkart's Avatar
Its there and running at all times displaying my choice of gauges as I ride. There are 4 screens of digital gauges(20 readings total I believe) that you can scroll through at will while riding. You can pick and choose(from approx. 30 available ecm signals), what readings you want and how/where to display them. I'm an information hound, and gearhead, I like knowing what's going on.
Besides the gauges, it's also an auto tuner, mileage/trip computer, a code reader and probably a couple other things I'm forgetting. The Power Vision is constantly evolving, Dynojet is adding features as they go which are included in free firmware updates.
Money well spent IMO.
tdkkart is offline
Passenger floorboard mounts. No spring, no ball. Mounts only.40.00 shipped neverdone Sold 1 05-13-2014 06:57 PM
PV: Ran Auto Tune NO Change in Map? RhinoHD ECM/Fuel Management systems 14 07-22-2013 11:52 AM
Ever mount PV here......... FlatOut ECM/Fuel Management systems 5 04-12-2013 08:37 PM
No 6th gear light, no cruise scsharp2260 ECM/Fuel Management systems 5 01-17-2013 02:14 PM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 05:02 PM
