fails to start - Road Glide Forums
post #1 of 12 (permalink) Old 07-04-2013, 10:31 AM Thread Starter
fails to start
I have a 2011 RGU, 11,000 miles, recently had cams, true duals, PCV and tune. Runs GREAT! On 2 occasions after brief stops, it has refused to start. Fob on belt, turn ignition and kill switch repeatedly. Engine lite usually does not come on, but sometimes comes on and off, but without whoosh of ready to start. Eventually started both times. So far only when engine is hot. I have an apt at local stealer for Julu 16. Any ideas as to what this could be?
2011 RGU, Kuryaken pegs and grips, hd backrest, jaybrake forward controls
big tex is offline
post #2 of 12 (permalink) Old 07-04-2013, 10:42 AM
It may be that the PCV is not booting and turning the ignition on/off re-boots the PCV. Have you checked for DTC codes?
post #3 of 12 (permalink) Old 07-04-2013, 10:59 AM Thread Starter
No, how do I do that?
big tex is offline
post #4 of 12 (permalink) Old 07-04-2013, 11:11 AM
mjsdouble's Avatar
Could be as simple as replacing battery in the FOB.
SWIII, SWIV, SWV, SWVI & SWVII
mjsdouble is offline
post #5 of 12 (permalink) Old 07-04-2013, 11:26 AM
tdkkart's Avatar
If it was a FOB problem the blinkers etc would go nuts when you tried starting it. If that acts normal you can discount the FOB as the problem.
It really sounds like you have no power, do the headlights etc come on?? If not it may just be a bad battery connection of circuit breaker issue.
tdkkart is online now
post #6 of 12 (permalink) Old 07-04-2013, 02:56 PM Thread Starter
Just replaced the battery. Keep it on the charger 1/2 the time. No security lights.Eventually fired up the 2 times it's happened so far.
big tex is offline
post #7 of 12 (permalink) Old 07-04-2013, 03:00 PM
tdkkart's Avatar
Before or after this issue started??
post #8 of 12 (permalink) Old 07-04-2013, 03:34 PM Thread Starter
It started before
big tex is offline
post #9 of 12 (permalink) Old 07-04-2013, 03:35 PM Thread Starter
Oops. I replaced battery maybe 1 month ago. Charger already in use.
big tex is offline
post #10 of 12 (permalink) Old 07-04-2013, 06:39 PM
The info on how to check the DTC codes are in the stickys in the troubleshooting section of this forum.
Crank no start, crank start Sam07 Troubleshooting for Road Glides 10 05-15-2018 08:03 AM
Start-up Question OldSalt Road Glide Specific Discussions 17 01-19-2011 09:05 PM
Start Date NakedSnowman General Off-Topic Discussions 8 01-05-2011 06:03 PM
bike won't start briscoe *General Road Glide Discussions/Pictures 11 11-28-2010 10:25 AM
Bike will not start pte359 Troubleshooting for Road Glides 13 08-19-2010 03:55 PM
