check engine light - Road Glide Forums
post #1 of 8 (permalink) Old 07-04-2013, 01:40 PM Thread Starter
mdjr47's Avatar
check engine light
Never had a problem with my 09 road Glide. Took it for a ride today and the check engine light came on and I couldn't accelerate. Had to coast to a stop and shut the engine off. Started it back up ,light cleared,and it ran normal. Then after about a half hour it did it again. Any help out there?
mdjr47 is offline
post #2 of 8 (permalink) Old 07-04-2013, 02:07 PM
Read the stickys in the troubleshooting section and you may find a solution to your problem. Learn how to find and clear DTC's may help you get the bike running and the TT418 service bulletin may give you a possible fix to your problem.
post #3 of 8 (permalink) Old 07-04-2013, 02:25 PM Thread Starter
mdjr47's Avatar
Thanks. I retrieved the codes P 1511 and P2135. Somebody told me it might be a connector.
mdjr47 is offline
post #4 of 8 (permalink) Old 07-05-2013, 09:17 AM
As explained in the HD service bulletin TT418A the fix is the use of "Dielectric Grease" on the Throttle Control Actuator (TCA) plug that is located to the rear of the air cleaner. Your P1511 is the main code and the P2135 is the secondary code but niether one is the problem. Because the pins in the TCA plug lost the perfect connection the TCA failed to function properly and the bike went into limp mode. Read the TT418A bulletin in the stickys for all of the details and go to your HD and bring this bulletin to their attention and they should re-pin the TCA plug with the 2010 style pins at no cost to you. I have yet to do a pin replacement because the dielectric grease has been working well for me. HD put new style (gold plated) pins in the 2010 and later models to help eliminate the corrosion that occurs on the earlier style 08 & 09 style TCA pins.
post #5 of 8 (permalink) Old 07-05-2013, 09:46 AM
Easyryder01's Avatar
Who needs the dealership techs ! This is the place to go to. .....love this place. Sometimes I think spending so much time on here make get me divorced ! Lmao
2017 RGS Velocity Red
Easyryder01 is offline
post #6 of 8 (permalink) Old 07-05-2013, 03:48 PM Thread Starter
mdjr47's Avatar
Thanks. I will try the dielectric grease. Was there a recall on those pins?
mdjr47 is offline
post #7 of 8 (permalink) Old 07-05-2013, 03:54 PM
ammojeff's Avatar
+1 on tech advice ironmark be da man!
AMMO: Giving the enemy the opportunity to die for their country
ammojeff is offline
post #8 of 8 (permalink) Old 07-06-2013, 08:48 AM
No there was not a recall on the pins but when you bring the TT418A service bulletin to the attention of the HD service manager they should re-pin the TCA plug for free.
Check Engine Light and Battery Light following Jackpot 2-1-2 install PearlBlueUltra Troubleshooting for Road Glides 9 06-15-2014 03:59 PM
Check Engine Light Ran8175 Troubleshooting for Road Glides 0 07-17-2011 01:17 PM
05 Roadglide check engine light camperfan Troubleshooting for Road Glides 8 05-03-2011 07:36 AM
Engine check light keeps coming on 2011 RGC madmatt Road Glide Specific Discussions 11 02-13-2011 11:14 PM
Oil Overfill and Check Engine light Biker Tom Troubleshooting for Road Glides 5 09-15-2010 07:01 AM
