powercommander 5 with true duals - Road Glide Forums
post #1 of 5 (permalink) Old 07-07-2013, 10:51 PM Thread Starter
jaysrgu's Avatar
last weekend I put a set of vance and hines true dual pipes and there slip on mufflers,cant remember which ones,not the oval ones and a powercommander 5,now on the dyno it made great power,86 hp and 106 trq,but it sounds like a Yamaha,i cant stand the sound at all,wondering several things here,first why does it have this loud tingy sound to it? secondly when idling it sometimes will stall,i have played around with the map and got it to run better by taking fuel away at 750-1250 rpm ,but the worst part is it has this wicked popping when decelerating,no exhaust leaks at all,so im reading the dynojet website and they say on the newer Delphi injection to set the 0 throttle position to 25,can anyone help,lol I took fuel away to make it idle better but it pops like a tincan,help!
jaysrgu is offline
post #2 of 5 (permalink) Old 07-10-2013, 12:03 AM Thread Starter
jaysrgu's Avatar
54 views and no replys come on shark tank!!
jaysrgu is offline
post #3 of 5 (permalink) Old 07-10-2013, 12:27 AM
RichieRich's Avatar
Where did you get your base
Map? Have you.called dynojet for tech support?
2013 BBP FLTRX
RichieRich is offline
post #4 of 5 (permalink) Old 07-17-2013, 10:48 PM Thread Starter
jaysrgu's Avatar
I ended up adding fuel at the 0,2,and 5 % throttle at certain rpms to keep the popping down,alot of it by the seat of my pants,make a few adjustments and drive it,make a few more ect ect sounds great runs hard and im happy
jaysrgu is offline
post #5 of 5 (permalink) Old 07-17-2013, 11:27 PM
RichieRich's Avatar
Glad you got it straight
2013 BBP FLTRX
Factory duals or true duals Diverrick Intake and Exhaust 14 01-24-2016 01:47 PM
True duals or power duals LUCKY13 Intake and Exhaust 16 01-11-2016 08:44 PM
Rinehart true duals 4" or V&H dresser duals with monster rounds iambill Intake and Exhaust 5 10-18-2014 07:49 AM
True definition of true duals? cypress Intake and Exhaust 8 06-23-2012 09:22 PM
Thunderheader true duals/MGS true duals JKRSDETROIT Intake and Exhaust 2 03-26-2012 12:06 PM
