Powervision problem - Road Glide Forums
post #1 of 12 (permalink) Old 07-13-2013, 06:11 PM Thread Starter
Powervision problem
Installed Power Vision and Auto Tune on my 2013 HARLEY a few weeks ago. Started with Dynojet Download for my Rush 2 into 1 and SE Breather and started to Autotune. Great system and bike runs great.
Riding to work I had the gauge showing AFR and Lamba for both cylinders and suddenly the front goes blank. I checked for a loose connection and all looked well. When I got home later I swapped 02 sensors front to back and now back does not work. Swapped around cables and wires going into Auto tune box and still no response from the marked problem 02 sensor.
I contacted Power Vision support via email and Roy was nice enough to respond quickly. I have used DynoJet on my bikes for tuning since 1978 and always receive excellent customer service from them. I currently have their Jet Kit in my XR650R, a PCV on my ZX14 and the Powervision on my Harley.
Response from Dynojet---------Yes, try the gas test on both sensors, connected to both harnesses. Unfortunately there is no warranty on an o2 sensor. The most likely reason we see early o2 sensor failure is one that was dropped, or one that the wire harness was bent very close to the metal sensor. The next most common reasons are leaded fuel, or a two stroke engine. Outside of these reasons, o2 sensors usually last a long time.
This was not the response I thought I would get from Dynojet on a $1000 dollar system that was just installed for a week of use. Great system Poor customer Service in my opinion.
Eric Eckhoff
Mile High Harley-Davidson
Aurora, Co
deadwood1584 is offline
post #2 of 12 (permalink) Old 07-15-2013, 06:15 PM
How much $$ is an o2 sensor??
HeatWave is offline
post #3 of 12 (permalink) Old 07-15-2013, 06:44 PM
Interesting my buddy is having an o2 sensor problem on his cvo ultra since the pv
It could however just be a bad sensor covered under warranty
2013 RGU, black of course....
y2kflhr is offline
post #4 of 12 (permalink) Old 07-15-2013, 08:48 PM
FYI
overvoltage has shorted the O2 heaters, which causes the sensors to fault. I believe there's a protective circuit which yanks them offline in such a case, as the sensors only fault when the engine's running and under load, but the O2 heater code comes up KOEO
Are you getting any codes?
y2kflhr is offline
post #5 of 12 (permalink) Old 07-15-2013, 09:57 PM
rageglide's Avatar
PV doesn't control O2 voltage, the ECM does.
I suppose if someone altered the parameters for closed loop to the point that it's trying to hold a closed loop far outside of the reliable range, maybe that would damage the O2. Not sure... just speculating.
2012 fltrx
rageglide is offline
post #6 of 12 (permalink) Old 07-15-2013, 11:20 PM Thread Starter
The wide band sensor is only $110. Not a big deal. Just frustrated that it quit working after a few days and being told no warranty. Don't know what could have taken it out. No drops, kinks in wires or chemicals. Just working and then stopped. Just curious if anyone else has had issues like this.
Eric Eckhoff
Aurora, Co
post #7 of 12 (permalink) Old 07-19-2013, 11:19 AM
It looks like the sensor in the speedometer is what is causing the voltage problem on my buddies bike, still in the shop
y2kflhr is offline
post #8 of 12 (permalink) Old 08-14-2013, 07:57 PM
Crzylgzz's Avatar
try the old fashioned method of cleaning the 02 sensor. sounds dumb, but sometimes they get so fouled they just stop reading.
Crzylgzz is offline
post #9 of 12 (permalink) Old 08-15-2013, 05:57 AM
piggs's Avatar
deadwood, i have nothing to do with FM except i bought mt PV1 from them. I dont understand how youd concider it bad customer service because they think its a bad O2 sensor and not covered under warranty.. HD warranty? u say the bike runs great? u are not happy because the bike runs great but the O2 sensor on the PV says it isnt working?? i'm missing something..
Piggs, SemperFi
2013 FLTRX Denim
piggs is offline
post #10 of 12 (permalink) Old 08-15-2013, 11:41 AM
I think he is talking about power vision pro auto tune not the factory O2 sensor. Check the link it should clear things up for you
http://www.dynojet.com/powervision/p...e-details.aspx
vaughtcity is offline
SE 204 Cam Powervision tune kiohio Map Section 7 12-26-2014 07:11 AM
Powervision mounted Singlebeam ECM/Fuel Management systems 28 10-15-2013 01:06 AM
Powervision trip/fuel gauges issue baldwookie ECM/Fuel Management systems 0 07-04-2013 03:11 PM
PowerVision - Do you Scale or Cap? rageglide ECM/Fuel Management systems 5 06-19-2013 12:29 AM
Powervision Users smitty ECM/Fuel Management systems 9 07-20-2012 10:30 PM
