Fuel Pak Fail - Road Glide Forums
post #1 of 5 (permalink) Old 07-21-2013, 01:27 PM Thread Starter
Fuel Pak Fail
If my Vance and Hines Fuel Pak quits working on my 2013 road glide, can I simply unplug and then the bike will run long enough to get to dealer.
Schmaxx is offline
post #2 of 5 (permalink) Old 07-21-2013, 02:07 PM
crossbonesglide's Avatar
Yes, your bike's EMC will return to the factory settings with the Fuel Pak removed. Probably will take a few minutes to adjust itself.
crossbonesglide is offline
post #3 of 5 (permalink) Old 07-21-2013, 02:10 PM
calgaryglide's Avatar
Short answer is yes. I had Fuelpak take a dump, the bike ran ok but hot (lean) with a high flow air cleaner and true dual and pipes. If your bike is stock, not stage 1 should be no problem at all.
2019 FLTRU, Tyggr
calgaryglide is online now
post #4 of 5 (permalink) Old 07-21-2013, 03:40 PM Thread Starter
Thanks for the replies. I was just curious if it went out on the road could it get me home or to dealer. I have a stage one with a/f and pipes and no cat.
Schmaxx is offline
post #5 of 5 (permalink) Old 07-21-2013, 05:00 PM
I had 32K on my last Fuel Pak with 0 issues. I wouldn't worry too much about it as long as the connector is sealed good.
DuraGlide is offline
I fail completely someone help! 11FLTRX103 Lighting 20 01-24-2013 03:11 PM
cooling fan fail arkieglide *General Road Glide Discussions/Pictures 1 08-06-2012 02:03 PM
Tour Glide fairing fail? Monkeyman *General Road Glide Discussions/Pictures 18 12-12-2011 01:27 AM
Cold Temp. Tach & Speedo fail ??? Florida Cracker Troubleshooting for Road Glides 5 10-19-2010 04:22 PM
Sirius Sportster - fail - replace with? Sincecrazy Aftermarket Accessories 6 09-24-2010 10:29 AM
