PV: Ran Auto Tune NO Change in Map? - Road Glide Forums
post #1 of 15 (permalink) Old 07-21-2013, 07:08 PM Thread Starter
RhinoHD's Avatar
So yesterday I did an auto tune run. I spent about 30 min driving around in various driving conditions. Re flashed and headed home. Bike ran good except for this stupid POP when up shifting but that's for another thread.
Today I download the auto tune map I saved to a slot and did a compare and no changes at all? Is this normal?
Life is good but it's not easy!
RhinoHD is offline
post #2 of 15 (permalink) Old 07-21-2013, 07:51 PM
Short answer is no
2013 RGU, black of course....
y2kflhr is offline
post #3 of 15 (permalink) Old 07-21-2013, 08:53 PM Thread Starter
RhinoHD's Avatar
So where do I go from here?
RhinoHD is offline
post #4 of 15 (permalink) Old 07-21-2013, 09:48 PM
tdkkart's Avatar
Where did you look for changes??
When doing an autotune, the only changes you will see will be in the VE front and rear charts in the airflow folder.
tdkkart is online now
post #5 of 15 (permalink) Old 07-21-2013, 10:28 PM
I get the same thing with three different auto tune runs AND when I compare different maps from dyno jet for differenent configs. Using compare function in win PV. In compare all cells are 0.0 Sorry, know that doesn't answer your question.
2012 RGU, Stage One, VH Dresser Duals, Monster Ovals, Powervision.
ThunderAO is offline
post #6 of 15 (permalink) Old 07-22-2013, 12:11 AM
rageglide's Avatar
Try and grab the logs using WinPV - I believe you can use them in log tuner like before PV integrated autotune.
Sounds like you may not have exported the tune. Did you save an Autotune_results file in one of your slots?
2012 fltrx
rageglide is offline
post #7 of 15 (permalink) Old 07-22-2013, 12:18 AM
rageglide's Avatar
Going to go on a limb and say you're not doing it right.
Flash tune with your base.
Go into Autotune and Enable AT, which forces a restart
Go into Autotune screen again hit logging so you can see the green screen
Ride
Park, export tune,
Save to a slot, called somethng like Autotune_results00xx
Now, Flash that tune to the ECM and you'll be using the Tuned tune...
Sorry if you know this already. But I screwed it up a few times when I started too.
I've been saving the logs and NOT autotuning lately then using log tuner like before. Been having pretty good results
2012 fltrx
post #8 of 15 (permalink) Old 07-22-2013, 12:22 AM
RenegadeSteve's Avatar
Hows that work? Ive only used auto tune pro so far
2012 Road Glide custom, vivid Black, full boom audio system, windsplitter windshield, heritage bars, stealth rack and detach sissy bar. Mean city cycles seat mod with ostrich inserts
RenegadeSteve is offline
post #9 of 15 (permalink) Old 07-22-2013, 05:48 AM Thread Starter
RhinoHD's Avatar
I didn't save the logs next run I will.
Well I watched the video instructions before I went out to do the run. I am using Basic auto tune. I noted every step and followed it carefully. I did do the export and did do a flash. Very strange. I was checking for changes in WinPV which flags any differences when doing a compare. I will try it again today and see what happens..
RhinoHD is offline
post #10 of 15 (permalink) Old 07-22-2013, 06:07 AM Thread Starter
RhinoHD's Avatar
Here is a pic of a a compare between two maps I received from FM. These are all the items that were included. Which tables are the "VE" tables. Forgive me I an new to doing this.
Here is a sample of what I was looking to see after the AT run.
It's a compare of two FM maps which shows changes only in the Lambda table.
RhinoHD is offline
To auto-tune, or not to auto-tune Magnum ECM/Fuel Management systems 12 08-27-2014 06:25 PM
Auto tune run with PV gja ECM/Fuel Management systems 2 05-29-2014 10:34 PM
PV Auto tune not naming files sequentially Cash_ ECM/Fuel Management systems 1 06-07-2013 06:04 PM
auto tune vs no auto tune Jacket4256 ECM/Fuel Management systems 18 06-01-2013 08:12 PM
PV auto tune Deadstroke ECM/Fuel Management systems 0 04-23-2013 09:06 AM
