pc5 & autotune - Road Glide Forums
post #1 of 8 (permalink) Old 07-22-2013, 09:56 AM Thread Starter
jerseyjeff62's Avatar
pc5 & autotune
i had my laptop hooked up while i was idling and notice that i had 2 devices connected but the autotune light was not on, it would come on when i hit 2,000 rpm.is there anyway to have this on in idle mode?
2017 Road Glide Special
Laguna Orange
jerseyjeff62 is offline
post #2 of 8 (permalink) Old 07-24-2013, 09:42 AM
Mine did that until I installed the latest firmware for it. That seemed to fix several issues. Hope that helps.
scsharp2260
'09 Road Glide
PC V w/ Auto Tuner
Bub Series 7 Stealth Mufflers
scsharp2260 is offline
post #3 of 8 (permalink) Old 07-24-2013, 03:07 PM Thread Starter
firmware for what the pc 5 or the autotune?
Laguna Orange
post #4 of 8 (permalink) Old 07-27-2013, 11:49 AM
mitchdm's Avatar
Firmware for the PCV I am guessing ~ I just put this on my Skunk this week ~ been runnin to lean with the 113 build, I know the autotune is working just need to lay some miles down and save the trims. Jamie did not put a base map in since we were unsure of the current build specs ~ The bike runs great with the few miles I have ridden with the autotune doing it's thing. I have utilized the PCV and autotune on my last two bikes logging over 160k combined. I think with the way we mod our bikes and the questionable ability and expense of some of the tuners this is the way to go ~ SemperFi
mitchdm is offline
post #5 of 8 (permalink) Old 07-27-2013, 05:17 PM
If we can't get the SEPST sorted out, 'going with the PCV Auto
HeatWave is offline
post #6 of 8 (permalink) Old 08-01-2013, 09:19 AM
EFI tuning and Exhaust Expert
fuelmoto's Avatar
Your AT is working properly, however the AFR tables are not configured to adjust the base tune in certain areas such as idle and decel. This can be noted if you retrieve the map and refer to the AFR table. For idle mixture adjustment we generally recommend setting this manually with the PC software watching the live AFR.
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #7 of 8 (permalink) Old 08-02-2013, 08:25 AM Thread Starter
thanks for the tip.i since removed the pc5 & at because i'm have a charging issue at hot idle and dealer blamed this then charged me for time.but still having issues without it on so i guess they were wrong huh
Laguna Orange
post #8 of 8 (permalink) Old 08-05-2013, 12:53 PM
jaysrgu's Avatar
been running the auto tune for the last week or so,after 5 or 6 good rides the numbers the last 2 times have been almost the same,as I understand it that's a complete autotune,now my issue is im still getting that annoying popping on decal from 0-2% (guessing here) around 2200 rpm down,which way do I go here more fuel or less fuel?
jaysrgu is offline
Putting in cam, is PC5 ok to use Brianu1 ECM/Fuel Management systems 8 08-24-2015 06:34 PM
PC5 with Autotune Eric Lis Parts for Sale 13 09-06-2014 11:08 PM
PC5 with auto tune. HELP!!! OneSlickGlide ECM/Fuel Management systems 9 06-23-2014 11:24 PM
Another PC5 & auto tune ? OneSlickGlide ECM/Fuel Management systems 0 05-03-2014 06:07 AM
Pc5 OneSlickGlide ECM/Fuel Management systems 2 04-23-2014 08:40 AM
