Power Commander install/remove - Road Glide Forums
post #1 of 3 (permalink) Old 07-24-2013, 06:45 AM Thread Starter
My new Power Vision from Fuel Moto is coming in today (finally) and need to pull the PCV. Do I have to pull the main fuse before I disconnect the PCV, or can I just pull it with the ignition off?
Thanks
Mugs RG is offline
post #2 of 3 (permalink) Old 07-24-2013, 07:09 AM
mocotom's Avatar
It's a good idea to pull the fuse anytime you are working with the ECM.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #3 of 3 (permalink) Old 07-24-2013, 07:52 AM
OldNerdGuy's Avatar
It is a good idea to pull the main fuse when working anything electrical, except the starter. To work on the starter, you MUST pull the battery connections, both of them. The Plus cable goes directly from the battery to the starter motor, and from there to the rest of the electrical system.
OldNerdGuy is offline
how to remove power terminal on gps wires jethro_3 GPS 3 01-02-2017 07:35 AM
Unplugged all wiring to remove fairing, doesn't get power anymore dinggus Troubleshooting for Road Glides 32 08-09-2016 04:44 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
Power commander price? BillyBob *General Road Glide Discussions/Pictures 2 03-28-2010 08:57 AM
Power Commander V and Big Sucker Air Cleaner The Infamous Sharknose Equipment-RG 0 09-18-2009 10:07 AM
