Dropping a map into a SERT - Road Glide Forums
post #1 of 1 (permalink) Old 02-28-2011, 07:52 AM Thread Starter
BigDaveOnBass's Avatar
Send a message via Yahoo to BigDaveOnBass
I had a map that a west coast tuner was kind enough to "lend" me back in May after I did my 95" build. I've been holding on to it since I got it, for the last 2,500 miles of riding, and because my bike seemed to be running OK. I was also intimidated by the thought of hooking up a computer to my bike and possibly screwing up my tune up somehow. I finally got passed my fears and hooked up the laptop to the bike and Race Tuner and dropped in the map. It was so freaking easy I couldn't believe it! It took a minute or so for it to download. My bike had been running a bit lean, but not any more. It's so much more responsive in all throttle positions and operating ranges. I don't know why I waited so long. The next step will be to take it to the local H-D shop for a base line dyno run and some (hopefully) minor tweaking to the map, but right now, I'm satisfied with it as it is. If I put it on the dyno and get @ 85-95HP and 90-100 ft/lbs torque, I'll consider it "mission accomplished."
'04 FLTRI, originally Smokey Gold, now Vivid Black, 95", S/E forged high comp 9.6:1 pistons, Andrews 37G cams, Big Boyz heads, S/E adjustable pushrods, S/E Race Tuner, S/E Stage 1 kit, V&H Dresser Duals, S/E slip ons, H-D premium oil cooler, chromed wagon wheels, Brembo/H-D front brakes, added rear engine guards, Paul Yaffe 10" OEM Monkey Bars, detachable tour pak
BigDaveOnBass is offline
Sert map needed.......... BAM BAM Map Section 6 07-15-2013 09:58 PM
SERT Map needed 2012 103" scooterroid Map Section 4 05-11-2013 05:15 PM
Base map for SERT Too Short Intake and Exhaust 0 07-23-2012 07:40 AM
Question on SERT map for 2010 Too Short ECM/Fuel Management systems 0 07-15-2012 01:23 PM
Dropping the bomb..... zombie Engine Related 5 01-16-2012 06:41 PM
