SEPST help... - Road Glide Forums
post #1 of 9 (permalink) Old 07-28-2013, 08:55 PM Thread Starter
SEPST help...
Ok so I just installed the super tuner onto my 2005 RG. I only have a stage 1 setup at this point, thunderheader and Roland Sands Design a/c. when I loaded the base map last night, I didn't realize to click the "enable Smart tune reflash" box. I think this is my issue but am not sure.
I did use the Smart tune record feature on the VCI today and downloaded that recording to my laptop. Now, when I load the base map, according to the directions, I cannot get the smart tune option under the VE front and rear cylinder values.
At this point, I have no friggin idea what I did wrong or how to fix it. ANY help is appreciated at this point..
Major99 is offline
post #2 of 9 (permalink) Old 07-30-2013, 09:14 AM
That sounds like your problem as best I can remember. Its been awhile since I retuned using the Smart Tune.
1st select your base tune and open your WORKING VE TABLE
2ND OPEN YOUR SMART TUNE TABLE
3RD CLICK ON ADD BUTTON
4TH CLICK ON GENERATE BUTTON
5TH CLICK ON UP DATE BUTTON
THEN SAVE FILE UNDER NEW NAME
RE-FLASH BIKE
DON'T FORGET TO CLICK THE ADAPTIVE FUEL BOX AND THEN RE-FLASH. DO NOT CLICK ON SMART TUNE UNLESS YOU ARE GOING TO MAKE SOME MORE RUNS.
Usually before I re-flash I will open the VE tables as both a Table and Graph. Look for any outlaying value IE if you have a 115 surrounded by a bunch of 95 values or the opposite a low value surrounded by higher values I will spit the difference between the surrounding values. So in this case I would make the value a 105. That is an extreme example but I try to smooth the table as much as possible. Peaks and valleys are fine but it shouldn't look like the Grand Tetons. (Just my opinion.)
Tom
Lord Help me to be the Man my Dog thinks I am!
TearlessTom is offline
post #3 of 9 (permalink) Old 07-30-2013, 09:23 AM Thread Starter
That's my problem right now, I cant open the Smart Tune option because it doesn't show up. I think I will Take another ride and make another recording and start from scratch..
Major99 is offline
post #4 of 9 (permalink) Old 07-30-2013, 09:26 AM
Is your VCI blinking when you make your runs?
Are you hitting the button BEFORE turning the bike off. Turning it from blinking to solid. If not you loose the info.
If it is fully red you VCI is full and needs to be loaded. If not blinking it is not recording.
Tom
post #5 of 9 (permalink) Old 07-30-2013, 09:31 AM Thread Starter
yes. the LED was blinking on the VCI as I was riding. I did pull over after about 45 minutes to get gas and pressed the button on the VCI BEFORE I shut the bike off which made it solid red. when I got home, I disconnected it from the bike before connecting it to my laptop. The file it downloaded was an .hdx file but all of the canned maps are .dt0 don't know if I didn't record long enough or if I shouldn't have unplugged the VCI from the bike before hooking to the laptop...
I obviously did something wrong though..lol
Major99 is offline
post #6 of 9 (permalink) Old 07-30-2013, 09:35 AM
That may be your problem. I always download while still connected to the bike. It has to have a power source the lap top does not power it up
Try hooking it back to the bike. turn the bike on and download to laptop then turn bike off
Tom
post #7 of 9 (permalink) Old 07-30-2013, 09:41 AM Thread Starter
Thanks..I may not get to it till tomorrow or Thursday but I will keep you posted. I really appreciate the input...HD isn't big on tutorials.
Major99 is offline
post #8 of 9 (permalink) Old 07-31-2013, 09:04 PM
In your home screen do you have these buttons. The How to Smart Tune Button has good directions. Also under Tech Tips you can look up Manual and it tells you how to download the manual and print it out.
Tom
post #9 of 9 (permalink) Old 08-02-2013, 02:40 PM
Here is a link to a step by step how to smart tune. It is easier to follow than the HD version.
http://www.harley-davidson-hangout.c...une-sepst.html
Tom
Need help with SEPST Ezgravy ECM/Fuel Management systems 12 06-03-2013 08:57 AM
Need input, SEPST or another T-Max DarbinCo ECM/Fuel Management systems 13 04-26-2012 11:53 AM
Sepst cbell11 ECM/Fuel Management systems 12 03-11-2012 06:11 PM
Anyone have a SEPST Map? PC PaiN ECM/Fuel Management systems 0 02-17-2011 10:27 PM
SEPST Map for 09 Dresser Duals Grillfish ECM/Fuel Management systems 0 01-14-2011 02:08 PM
