Autotune trouble - Road Glide Forums
post #1 of 3 (permalink) Old 07-29-2013, 10:13 AM Thread Starter
Unhappy Autotune trouble
Ran into an odd situation last night. I did a 40 minute tune run, mostly highway, flashed new tune and took a 20 minute ice cream run. When I got back to the house after another 15-20 minute ride shut down to open my trailer. When I turned key to ignition, fuel pump ran and engine light stayed on, I recycled and engine light stayed on. I started the bike and it barley started and ran and sounded like SHEET!! Definite clicking sound and no throttle response, sputter and stall. I recycled tried again and same. So I re-flashed using FM Base tune and she started and ran OK...??? WTF??? I rode to work this morning and she seems to be OK. Has anyone run into a problem like this after auto tuning?? Is there an ideal time length or throttle range for tuning runs?? Appreciate any help as always!
2013 FLTRX, FM Jackpot 2-1-2 , FM A/C, 4" Rineharts,PVw/Autotune, Arlen Ness deep cut hot Legs, Progressive mono, Detach Tour Pak, 14" Windvest, Buky 12" Malo, JM XTs and AMP
twrguy is offline
post #2 of 3 (permalink) Old 07-29-2013, 11:31 AM
maybe your tune got corrupt? I would call FM and send them the updated map to see if they see anything
2013 RGU, black of course....
y2kflhr is offline
post #3 of 3 (permalink) Old 08-10-2013, 04:44 PM
mitchdm's Avatar
I had a similar issue ~ reloaded the original tune ~ bike started fine ~ found a wire on the at200 off of the rear o2 sensor had come loose.
mitchdm is offline
PCV Autotune 615McCord ECM/Fuel Management systems 3 11-26-2011 08:42 PM
PCV AutoTune full exhaust and stage 1 filter 615McCord Road Glide Specific Discussions 1 11-13-2011 07:20 PM
AutoTune, worth the $? Gonekat ECM/Fuel Management systems 4 04-24-2011 10:18 PM
Power Commander 5 With Autotune Modules works with all 96's Garcou Classifieds Archive (3 months old+) 4 01-10-2011 11:12 AM
Stock ECU & VH Fuelpak vs T-Max Autotune DAK47 ECM/Fuel Management systems 3 12-03-2010 09:48 PM
