What kind of hp-tq numbers for a good stage 1 dyno-tune - Road Glide Forums
post #1 of 14 (permalink) Old 08-04-2013, 11:30 AM Thread Starter
McGruder's Avatar
My 2013 RG is at the dealer finishing out a stage 1 setup by adding V&H Dresser Duals, SERT, and a Dyno-tune to combine with my 4" Rinehart slip-ons and Arlen Ness Big Sucker stage 1 breather. I got the SERT because a cam in the future is a distinct possibility.
I've read several times that some dealers use a template approach to Dyno-tuning, and don't really do much to optimize the tune. What kind of HP and TQ numbers should I expect for a stage 1 setup and a pretty good Dyno-tune? The Dyno-tune itself will cost $350, which seems middle of the road based on other posts I've read here.
McGruder is offline
post #2 of 14 (permalink) Old 08-04-2013, 01:36 PM
RGUrider's Avatar
I am sure others more knowledgeable will pipe up, I have similiar setup, used dealer to tune. HP 72.96 to 79.23, torque 94.61 to 97.06..Difference felt around 3500 rpm. More power and torque in mid range. I suspect the dealers do exactly what you say, template approach vice really try to tune it. My total time on dyno was 1 hour 20 minutes. Once I commit to stage 2, am gonna see if I can find a real tuner in the area.
RGUrider is offline
post #3 of 14 (permalink) Old 08-04-2013, 05:56 PM Thread Starter
McGruder's Avatar
I'm thinking I'd be pretty thrilled with 94-97 TQ
McGruder is offline
post #4 of 14 (permalink) Old 08-04-2013, 06:51 PM
Banned
I have Vance and Hines Power duals w/ their monster rounds slip ons, SE Air Cleaner, SERT
My local dealer did the tune, don't have the sheet in front of me but end numbers were about 85hp and 95tq. Really happy with the set up and the way the bike runs.
Sent from Motorcycle.com App
Scootin is offline
post #5 of 14 (permalink) Old 08-08-2013, 08:06 AM
ERod62's Avatar
10% hp and 5% tq average gains untill cam it. With a cam and good tunning mid to upper 90's hp and about 110 tq. Tq range depending on the cam. Many other post on that topic.
ERod62 is offline
post #6 of 14 (permalink) Old 08-10-2013, 09:29 PM Thread Starter
McGruder's Avatar
Just got her back. Header install and tune performed by Chesapeake Harley Davidson in Darlington, MD.
Max HP: 76.48
Max Torque: 98.54
The torque graph measures 95 and above in the very usable range of 2500-4000 rpm's, and drops off to 90 at 4500, and 80 at 5000. Very nice improvement over stock throughout the entire range. The sound is exactly what I was looking for. Mild, deep rumble when just cruising, but with a twist of the wrist she barks and gets the hell out of there. Very pleased with the results. I'll post a scan of the dyno sheet in the dyno results forum.
2013 RGC - SE Stage 4, V&H Dresser Duals, Rinehart 4", Progressive Monotubes/Ohlins 357, Khromewerks Extend Heritage bars, Daymakers,
J&M 500W XTP amp, 4 Rokker XX speakers, BADDAD lids, Road Tech 665
McGruder is offline
post #7 of 14 (permalink) Old 08-10-2013, 11:20 PM
bikerglasses's Avatar
Here's my dyno sheet. Shows difference between the regular stage 1 map and dyno tuned map.
https://www.roadglide.org/showthread.php?t=36985
I should ads:
Ness big sucker
MGS True Duals
PCV
Ian -- Tucson, Arizona
- MGS True Duals, Ness Big Sucker, 12' Twin Peaks, -1" Monotubes
bikerglasses is offline
post #8 of 14 (permalink) Old 08-11-2013, 06:28 AM Thread Starter
McGruder's Avatar
Those curves and numbers are very similar to mine. Really good given that the atmospheric temps during your tune were quite high too.
McGruder is offline
post #9 of 14 (permalink) Old 08-11-2013, 06:47 AM
watertrapper's Avatar
Arlen ness big sucker, v&h big shots, pcv, was @ 70.89hp to 74.03hp and 88.97 torque to 92.36...hope this helps.
watertrapper is offline
post #10 of 14 (permalink) Old 08-11-2013, 07:11 AM
mocotom's Avatar
Chesapeake Harley has a very good reputation. One of the best dealers I've ever worked with.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
Pro Charger Road Glide making 183 hp 151 tq BigDaveOnBass Videos 38 10-15-2018 01:18 PM
191HP 154 TQ Dragos Stage 3 107 Blower engine break in tune. DragoBikeWorks Dyno Results 8 08-06-2014 11:10 AM
New to Dyno and HP numbers Deadstroke Engine Related 9 03-26-2013 07:22 AM
107 stage 4 with Procharger 209 HP 169.05 tq DragoBikeWorks Engine Related 9 12-20-2012 02:15 PM
120 inch built with Dragula 2:1 151 HP 145 TQ DragoBikeWorks Dyno Results 2 08-25-2012 11:47 AM
