Right muffler turning gold already - Road Glide Forums
post #1 of 22 (permalink) Old 03-20-2011, 12:07 AM Thread Starter
Question Right muffler turning gold already
2011 FLTRU, only 250 miles on the bike, I had Bassani Reverse Megaphone slip-on's put on at the dealership with an SE Stage I air cleaner and a "download". I get "pops" when I rev the motor and I've even had a couple of them during normal decelleration. I also noticed tonight after only 250 miles on the bike, the right slip-on is already turning gold where it meets the stock headers.
I'm no mechanic, but I think all this means I'm running way lean ... I'm just wondering what that means long term. Should I inspect the plugs already? Do I spend even more money now on headers, SE SuperTuner and dyno tune? Is there a less expensive way to fix this? And is there a way I can tell if the dealership actually performed the "download"?
FishGlide is offline
post #2 of 22 (permalink) Old 03-20-2011, 12:35 AM
I'm sure you plan on taking it back to the dealer that did the work. You didn't say when it started to pop. You paid good money for the work. They need to make it right. I had BUB 7 & se A/C & remapped on my 07 & never had any of the problems you mentioned. I'm sure someone else will give you some info. Good luck.
Hillglide is offline
post #3 of 22 (permalink) Old 03-20-2011, 06:50 AM
hotrodad's Avatar
I'm sure the dealer will give you the usual response 'that's how all Harleys are' so be ready and don't accept it. They do run lean and that is one reason of the popping on decell. Another reason could be air leaks in the exhaust. If you hear popping when you rev it that is my guess. Either a manifold gasket got displaced when the Bassinis were installed or they didn't bother putting new manifold gaskets in thinking they'd get away with it being almost new. (if they had the headers off) There are ways to fix the lean problem but it means spending money. Get after the dealer and see what they can do for you.
2005 FLTRi
Black Pearl
Live to Ride ~ Ride to Live
hotrodad is offline
post #4 of 22 (permalink) Old 03-20-2011, 07:12 AM
The instigator's Avatar
I had the same problem on a 07 Ultra Classic. It all started when I fitted the stage 1 to the bike using VH turned down pipes along with VH fuel pak and air fitter. I was told by VH that this was caused by the motor running to lean, which also made it run hotter than it would on leaded fuel.
This was noticeable on the right hand pipe due to it only having a single wall. A few friends using the same set up with twin walled pipes where fine as the excessive heat never reached the outer wall.
I was told by VH there was no fix.
The instigator is offline
post #5 of 22 (permalink) Old 03-20-2011, 08:02 AM
easyrider9809's Avatar
Sounds like whatever the dealer downloaded is not giving your motor the proper fuel/air ratios thru certain rpms. I would take it back to the dealer to see if they can get it right. Your slip-on should not be turning brown on 50 degree day in March. These new bikes are set very lean out of the factory and will run hot. With the addition of the stage one air cleaner, you could be running even leaner. Long term....getting tuner like a SE SuperTuner, TTS, or Power Commander will reap benefits. The dyno tuner you select will probably have a preference of a certain tuning software that they feel comfortable with or have experience to tune that could be part of your decision.
easyrider9809 is offline
post #6 of 22 (permalink) Old 03-20-2011, 08:53 AM
hodgeaaco's Avatar
Sounds like there may be an exhaust leak somewhere. A slip-on should not cause that much of an issue, especially since you still have the stock header and cats. The catalytic converters are a big part of the issue with the pipes turning gold. My head pipes were blue and gold by the time I got home from the dealer (20 miles) and that was with an HD nightstick with open end pipe, SE AC, and the download, but I didn't have any popping.
Short of it is, yes, the bikes run lean and will cause some popping on decel when you change parts, but it sounds like you may have a leak somewhere. The short-term fix is take it back to the dealer to check all of the gaskets and bolts. Long-term fix is to get yourself a tuner; PC-V, TTS, HD SE, etc.
2010 FLTRX - "Black Plague"
hodgeaaco is offline
post #7 of 22 (permalink) Old 03-20-2011, 01:28 PM
firerodder's Avatar
I'm no mech. either.... but if the bike "pops" on decel, wouldn't that be a cause from too much unburned fuel?? The unburned tends to be caused by richer conditions instead of lean. My '07 runs a bit on the rich side and you can always tell this after a longer ride due to the black powdery residue on the rear of the bags. I'd like to get tuned leaner and extend my range... I enjoy the comments either way, just my $.02
firerodder is offline
post #8 of 22 (permalink) Old 03-20-2011, 01:44 PM
what kind of exhaust are you running
Jerry W. is offline
post #9 of 22 (permalink) Old 03-20-2011, 02:30 PM
hodgeaaco's Avatar
I have the Rush 2-1.
post #10 of 22 (permalink) Old 03-20-2011, 04:02 PM
The harley stage 1 download only works with harley parts, ie, se a/c, and se slip ons. If you use different slip ons, then the download is not matched to those mullfers, hence, this could be the issue because it is likely that the harley slip ons don't flow as well as the ones you put on. I've got the harley se a/c, stage 1 down load, and the se slip ons and everything works great.
2009 Road Glide
Black Pearl, ABS, Security, and Cruise
Stage 1 A/C, download, and SE Slipon's
S&S Flywheel-balanced and welded
Timken Bearings in the case
Progressive 412 12" shocks
2011 Seat.
jcanrun is offline
Tags
decel pop , download , lean , muffler bluing
Swapping D&D Louvered baffle muffler out for the wrapped perforated muffler question bigshaqa Intake and Exhaust 6 03-25-2016 02:23 PM
Dragula Chrome Muffler (Only the Muffler) for Sale Tytanium Parts for Sale 8 08-30-2014 07:39 PM
Rinehart Slip Ons turning yellow? REDRUM Intake and Exhaust 16 01-06-2014 09:49 PM
Survived a left turning car. akjeff Safety Area 21 09-14-2013 09:47 PM
Muffler turning blue at the neck...... Steve-ALA Intake and Exhaust 2 06-06-2010 09:34 AM
