PC V and stock RGC - Road Glide Forums
post #1 of 8 (permalink) Old 08-23-2013, 08:31 AM Thread Starter
toogood8p's Avatar
PC V and stock RGC
I will probably get blasted...but I have a quick question.
I would like to do the header, pipes, air cleaner and EFI on my 13 RGC. I want a EFI system that I can push forward in the future for any engine mods. I really like and I am familiar with the PC V.
Right now, funds are tight...but I am thinking of installing the PC V on my stock RGC.
Will I see enough of a difference in installing in now to warrant not being patient for the rest of the system??
Thanks
Bear, Prez, Kindred MC
13 FLTRX - Candy Orange - Daymakers, Custom Dynamics - LED turn signals, Kuryakyn Scythe mirrors, Iron Aces bracket, X-grip, floor board extensions, custom sundowner seat, black KW 8", PCV, auto tune, Stage 1 AC, Drago H-pipe, 4" Dragula mufflers.
toogood8p is offline
post #2 of 8 (permalink) Old 08-23-2013, 08:46 AM
DED HD's Avatar
PCV is Power Commander V or the Power Vision? When you install the PCV, it eliminates the use of the o2 sensors on your exhaust, so i dont think your bike would run, right. I would call and ask DynoJet or Dragos or Fuel Moto about it.
I dont think there would be any reason to install the PCV if you dont change the airbox and exhaust. And as said many times, you can change the pipes, or change the air box without needing a tune, but if you change both, you will need to change your tune.
'10 Red Custom:
DED HD is offline
post #3 of 8 (permalink) Old 08-23-2013, 08:58 AM Thread Starter
toogood8p's Avatar
I was referring to the Power Commander V.
I was planning on call Jamie @ Fuel Moto.
I am really interested in the 2-1-2 Drago system...that is coming in the next few months. I was also looking at the Fullsac headers or HV X pipe.
As for mufflers, I was thinking about CFR's mufflers.
I just don't have the funds to spring for everything right now.
post #4 of 8 (permalink) Old 08-23-2013, 09:00 AM
spyder_63703's Avatar
It will help a great bit actually. You will be able to richen the stock tune up to help cool of that lean running stock motor and reduce some engine heat. Plus when you change the ac and pipes you will be ready with just a simple email to get a new tune
spyder_63703 is offline
post #5 of 8 (permalink) Old 08-23-2013, 09:04 AM
Flexin's Avatar
There won't be a noticeable difference without making the other changes. You are not getting more air in the engine and not pushing it out any quicker.
There are maps for a stock filer and stock exhaust for a 96, 103 and 110 engine. You can put it on an load the correct map if you just want to tinker around. Nothing wrong with that, just load the correct map.
Flexin is offline
post #6 of 8 (permalink) Old 08-26-2013, 06:35 AM Thread Starter
toogood8p's Avatar
Spoke with Fuelmoto and decided to jump to the pc and the stage 1 ac. It is a step towards my ultimate goal... Next will be slip-on pipes... Then headers, stage 3 and auto-tune unit.
Fuelmoto said that the pcv and the stage 1 will help and make a difference.
post #7 of 8 (permalink) Old 06-20-2019, 05:37 PM
an email for a "good" tune??
I apologize everyone, I know this is dirt old but what email address do y'all use to get a great tune? I have a 12 RG ultra, ive taken off the tour pack, added CFR'S and a new air filter. had to spend the rest on a new sound system, Harley really sucks in that department.
thanks in advance for the replies,
jeff6146
Jeff6146 is offline
post #8 of 8 (permalink) Old 06-20-2019, 05:57 PM
jeff6146
What tunner are you running ????
Big_gary is online now
Blue and white RGC stock gauges and PSI gauge RichieRich Parts for Sale 23 03-20-2015 10:52 PM
Added and 11 CVO RGC Ultra instead of a 15 RGC lh4x4 *General Road Glide Discussions/Pictures 11 07-14-2014 09:21 PM
WTT: Stock RGU Seat for Stock RGC/Street Glide Seat JayKS Parts for Sale 12 10-23-2013 12:03 PM
Powerduals and pc-v hwork Intake and Exhaust 1 05-28-2013 06:58 PM
PC-V and 2 into 1 gkt33 ECM/Fuel Management systems 15 06-13-2011 08:22 AM
