Beware! Percision ems problem! - Road Glide Forums
post #1 of 30 (permalink) Old 04-28-2011, 06:09 PM Thread Starter
gabbyduffy's Avatar
Percision ems
I installed Rev. Perf. new EMS on my 2010 RG and now I'm having problems with it running way too rich, I Just got off the phone with the owner of Revperf. and let me tell you this guy is a class act. Brian is going to do whatever it takes to get my bike running rite. It turns out that the problem has nothing to do with the Precision EMS at all. The Bungs on my Fatcat are way to long and the 02 senser is not reading the exhaust properly. Brian is paying for me to ship the exhaust header to his shop and he's going to fix the problem with the bungs. WOW, I could not be happier with the way Revperf. is handling this situation. Its safe to say that I will be a life long customer of REVOLUTION PERFORMANCE.... A1 operation.
Last edited by gabbyduffy; 05-02-2011 at 09:08 AM. Reason: Revperf. fixed the problem, real class act.
gabbyduffy is offline
post #2 of 30 (permalink) Old 04-28-2011, 06:38 PM
Phil_FLTRX's Avatar
I can't give advice but I will wish you the best of luck in getting it all figured out!!!!!
I went with Thundermax Autotune and so far so good.
2011 Vivid Black FLTRX, 107" Rev Perf, Zippers Thundermax AT, Roland Sands Speed 7 AC, Iron Aces iPhone holder, 8" KW, V&H Duals & Black Widows, DDM HIDs, ARC 6.5's, S.E. ported heads, 30 tooth frt sprocket.
You never see a Harley parked outside of a Psychiatristís office, now do you.....
Phil_FLTRX is offline
post #3 of 30 (permalink) Old 04-28-2011, 07:23 PM
Send a message via Yahoo to x52gnr
I would call and talk to Brian first, I have dealt with him and he seems like a standup guy..I would hope he would make it right. Good luck and I hope it works out in your favor..
2011 Vivid black FLTRU
S/E Race tuner
S/E 255 cams
Jackpot 2-1-2 Headpipes
Fulsac modified oe mufflers
S/E high flow air cleaner
Bunch of other stuff...
x52gnr is offline
post #4 of 30 (permalink) Old 04-28-2011, 07:46 PM Thread Starter
gabbyduffy's Avatar
Ems
I have not talked to Brian yet but I have talked to Andrew. Yes Brian is a great guy I'm sure he's going to do whats rite.
post #5 of 30 (permalink) Old 04-28-2011, 09:44 PM Thread Starter
gabbyduffy's Avatar
Rev. Perf. is going to reflash my ecm and everything should be good.
post #6 of 30 (permalink) Old 04-28-2011, 09:50 PM
Originally Posted by gabbyduffy View Post
I was givin advise to do a (leakdown) blow by test. does anyone know how to do a blow by test?
take it to your mechanic they will have a leak down tester and know how to do it. It is an easy test but you need a leak down tester to do it. It just measures the amount of leakage past rings, valves etc. I think you should get your tune in line first and run it for a bit to see what it does. It would have to be really rich to wash the cylinders down.
jeff is offline
post #7 of 30 (permalink) Old 04-28-2011, 10:14 PM
Rowdy's Avatar
I am sorry to hear your having all of these problems. I was under the impression they had this worked out. Me and three of my partners have that tuner and me being the only one with a 2010 sent my ECM to Revolution they reflashed it and I haven't had any more issues, but mine just idled a little rough, nothing like you are describing. My builder spoke with Josh I believe. I can check tomorrow and let you know.
Good luck man.
Rowdy
Rowdy is offline
post #8 of 30 (permalink) Old 04-29-2011, 02:24 AM Thread Starter
gabbyduffy's Avatar
Thats what I'm going to do, reflash the ecm and go from there. Thanks.
post #9 of 30 (permalink) Old 04-29-2011, 05:27 AM
i would find a dealer that had a dyno that was equiped with an afr sniffer and have it checked to see what the afr is.
jeff is offline
post #10 of 30 (permalink) Old 04-29-2011, 05:49 AM
if it were that rich you would have seen it in the plugs,all that fuel has to go thru the heads before it could wash down the cyclinders.change the oil,and run it,and see whats up.
Jerry W. is offline
09 D&D Fatcat with Precision EMS gabbyduffy Intake and Exhaust 1 05-24-2011 09:47 PM
D&D Fatcat with precision EMS. gabbyduffy ECM/Fuel Management systems 2 05-03-2011 11:33 AM
rev perf ems on 09 serg digga25 ECM/Fuel Management systems 7 04-29-2011 11:14 PM
Revolution Precision EMS Install Overview fuelmoto ECM/Fuel Management systems 2 02-25-2011 04:09 AM
