PC-V with Auto Tuner problem - Road Glide Forums
post #1 of 8 (permalink) Old 05-02-2011, 08:00 AM Thread Starter
My buddy has an 05 Road Glide that was built to a 95. True duals (Rinehart), has the PC-V with auto tuner on it. Now some days he says it runs great, some days he says it's terrible (back fires, hesitates). He's not getting very good milage (35). Has anyone got any ideas for him? I told him to get rid of it and go to Rev Performance, but he can't afford it right now.
2009 Hot Red Sunglo, 107 build, S&S 551 cams, heads polished and ported, Vance & Hines Dresser Duals, Vance and Hines 4" rounds, REVOLUTION PERFORMANCE ems, Bad Seed bars, J&M amp and rokkers speakers, Sony DSX-S310, progressive 940's
RoadGlide0611 is offline
post #2 of 8 (permalink) Old 05-02-2011, 08:37 AM
I run that set up and it is a great system. Has he hooked it up to the computer and accepted the trim tables that the auto tuner has adj.? If you don't do that each time you start it is has to learn all over again. Have him call Dyna Jet, they are vary helpful and will walk him though it.
scsharp2260
'09 Road Glide
PC V w/ Auto Tuner
Bub Series 7 Stealth Mufflers
scsharp2260 is offline
post #3 of 8 (permalink) Old 05-02-2011, 10:13 AM
I have one and have no problems with it. He should check all connections and apply dielectric grease to them, especially the jumper that goes in the unused socket on the Autotune module. If the jumper doesn't make connection it disables the Autotune.
rc_chico is offline
post #4 of 8 (permalink) Old 05-02-2011, 12:28 PM
PCV with autotune is designed for 09 and up HDs how did your friend hook this up to an 05? Did he use the fuel moto retrofit kit? They are the only ones I know of that make this kit and if he did have him call Jamie there I'm sure he can help out. If he doesn't have that kit it's my understanding the PCV will simply not work on a pre-09.
rc74racer is offline
post #5 of 8 (permalink) Old 05-02-2011, 01:52 PM Thread Starter
Well I can tell you he has an 05 Road Glide, I don't think he got it from Jamie, and he has a PV-C with auto tuner. I saw it under his side panel.
post #6 of 8 (permalink) Old 05-02-2011, 02:13 PM
I'm not debating what he has perhaps he bought this unit used and didn't know but a PCV is not compatible with an 05 roadglide without the kit. You can go the dynojet website and it will tell you 09 and up touring models. If you search their site for compatible tuners for an 05 RG all you will get is a PC III. If your friend does not have the retrofit kit this tuner will not work on his bike and it's why he's having issues at least that is what I would assume at this point. I looked into putting this on my 08 and decided against it because I want something that was actual made for my bike.
post #7 of 8 (permalink) Old 05-02-2011, 02:25 PM Thread Starter
Well I check the web site too, you are right. It looks like the pc-v is suppose to be for 09's and later. I'll have to see now, if he has the adapter on it.
post #8 of 8 (permalink) Old 05-03-2011, 06:50 AM Thread Starter
Wow, I had him go out to his bike and look again, to see if it was a PC III or PC-V. Sure enough it's a PC-V with an auto tuner on it too. I told him what was suggested to lube the connection areas, so we will see.
Yet another PC V w/Auto tune rdx4me ECM/Fuel Management systems 5 07-12-2014 01:37 PM
Another PC-5 and Auto Tune question Uncleford ECM/Fuel Management systems 3 03-15-2014 05:00 PM
PC V auto tune not working gibrj ECM/Fuel Management systems 9 09-17-2013 09:54 PM
TV-3 versus PC-V with Auto Tune cleanrider ECM/Fuel Management systems 6 05-13-2011 12:14 PM
are you happy with your PC-V auto tune RoadGlide0611 ECM/Fuel Management systems 18 03-25-2011 09:05 AM
