Decel pops power vision - Road Glide Forums
post #1 of 3 (permalink) Old 09-05-2013, 10:51 PM Thread Starter
I have a 2012 with fuel Moto 107 port polished heads 888 cams, and Dragula 2-1. Getting decel pops. Any help
2012 Fltrx, 21" Sinister Sage, Arlen Ness modulars, Dynojet PV, KN Intake, AMCustom headers, HD 12" windshield, Hawg wired six pack 400w amp, Avon Grips, iron aces iPhone mount, Progressive Monotubes, RIDEON tire sealant, Avons... This has gotta stop... Soon!
willbglidin is offline
post #2 of 3 (permalink) Old 09-06-2013, 06:57 PM
jack6hd's Avatar
If you bought it at Fuel Moto, contact them, if not call Dyno Jet. I was able to get mine out using "Quick Tune". Best bet is to get the pro's to help.
2015 FXDL 2nd best HD on road
jack6hd is offline
post #3 of 3 (permalink) Old 09-10-2013, 07:18 PM
I had some before I added the PV and then they seemed to go away. Then, I started getting some pops when coming out of first gear. I had to replace my crash bar today and while I had the lowers off, I checked the exhaust flange nut torque. The front top nut was loose. I torqued it and checked the other three. They were all fine. Took it for 40 mile test ride and the popping and decel gurgling is gone. Popping is usually caused by a leaking exhaust system. Air gets in and any raw fuel ignites. Check out you exhaust system. You may even see some carbon traces at the joints that will help find a leak if you have one. You didn't mention a tuner but I'm pretty sure you are running a richer fuel mixture with your setup. That means more raw fuel in the exhaust on deceleration.
I have the Jackpot 2-1-2 head pipes and use the stainless donut seals at the head so the torque has to be right or they will leak. And now I know they will pop as well.
Captain13 is offline
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 02:37 PM
Fuel Moto video: Tuning for decel pop with Dynojet Power Vision fuelmoto Fuel Moto 0 09-12-2017 02:38 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
SE Headlight Bezel pops loose Stryke1 *General Road Glide Discussions/Pictures 8 12-07-2011 08:59 PM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 07:21 AM
