Powervision Autotune Basic - Road Glide Forums
post #1 of 9 (permalink) Old 09-09-2013, 12:41 PM Thread Starter
blj9511's Avatar
Just ordered my PV from FuelMoto. They are loading a custom map for my set up: 2013 FLTRX, FullSac "C" X-pipe, FullSac "recored" slipons, SE Stage 1 AC. My question is after I install the PV and flash the ECM with the custom map should I ride with the FuelMoto map or should I ride it and run an autotune basic and then flash the autotune results? Looking forward to playing around with the PV, hoping for good results.
2013 Road Glide Custom FLTRX Vivid Black
Fullsac "C" X-pipe, Fullsac "recore kit" slip ons, Ness "Big Sucker" AC, PowerVision tuned by FuelMoto
blj9511 is offline
post #2 of 9 (permalink) Old 09-09-2013, 01:01 PM
faststan's Avatar
I flashed mine and then ran the autotune basic. It will take into account the local air and elevation. JMO.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 9 (permalink) Old 09-09-2013, 02:21 PM
smitty901's Avatar
Try your map first if it runs as you like then save it and if you want to play around run AT basic on a copy.
The Dynojet has a lot of function to play with enjoy.
smitty901 is offline
post #4 of 9 (permalink) Old 09-12-2013, 07:58 PM
Easyryder01's Avatar
I just got and installed the pv with the map Jaimie installed and bike runs great. I too wonder since I am not a tuner or have such a unique ear to the engine and throttle feel as to what could be better to modify the tune, for those that have done the AT did it get that much more noticeable than the map that was originally put on by fuelmoto ?
2017 RGS Velocity Red
Easyryder01 is offline
post #5 of 9 (permalink) Old 09-12-2013, 08:10 PM
I ran about 3 or 4 runs and it's not night and day better but it is better, I still have a slight detonation at around 80 when I hit it hard when it's hot out I need to remount mine and work on that area
2013 RGU, black of course....
y2kflhr is offline
post #6 of 9 (permalink) Old 09-13-2013, 02:14 PM Thread Starter
blj9511's Avatar
Got my PV installed today and flashed the tune that Jamie included with it and I am very pleased with how it runs. I will run it this way for awhile and then start to play with some auto tunes and see how they perform. Really like the ability to swith between tunes.
blj9511 is offline
post #7 of 9 (permalink) Old 09-13-2013, 02:27 PM
piggs's Avatar
the first thing i 'accomplished' after flashing the ECM was to set the idle to 900rpms which helps with the transmission bangin away going into 1st, at 1000rpms.. havent autotuned yet. coming off of my 96 DWG, the RGC is a rocket with just exhaust and AC mod.. ship, i was happy with 80 cubic inches..
Piggs, SemperFi
2013 FLTRX Denim
piggs is offline
post #8 of 9 (permalink) Old 09-14-2013, 04:19 AM
Pv1
Run FueMoto's flash until you feel comfortable with changing things. When jamie sends a map out it is about as good as it gets. The difference in elevation will not affect your tune. as you play with the unit and you see what it can do and build a comfort level then use AT basic to enhance cells per your riding style.
2013 Road Glide Custom Pearl Orange 7-13-2013
cvanmete is offline
post #9 of 9 (permalink) Old 10-18-2013, 06:40 PM
The map they loaded on mine. After about three weeks, I did a 40 minute auto tune run that included everything from 35 mph speed limits to a full 20 minute interstate run. I ran the auto tune on the map Fuelmoto preloaded. What a wake up on my bike. It is so much stronger and the low end torque is pretty amazing. The auto tune made a significant positive difference. I plan on doing a couple more with the weather cooling down just to fine tune the map.
Captain13 is offline
Power vision Autotune basic input Brianu1 ECM/Fuel Management systems 18 06-18-2016 11:51 PM
PowerVision maps and Autotune blj9511 ECM/Fuel Management systems 4 08-19-2015 09:43 AM
Dynojet autotune for powervision 200.00 pat123 Parts for Sale 2 09-22-2014 04:18 PM
Dynojet Powervision,Autotune pro and Iron Aces road glide mount pat123 Parts for Sale 5 09-11-2014 11:16 PM
For Sale: V&H Basic Slip on pipes sheriff61 Classifieds Archive (3 months old+) 1 09-03-2010 01:27 PM
