TTS Mastertune & a New Header - Road Glide Forums
post #1 of 6 (permalink) Old 06-02-2011, 04:24 PM Thread Starter
Martin's Avatar
Location: So. Cal native currently in the Battle Born State of Nevada
This weekend I will be putting V&H Power Duals on my 11 FLTRX along with the TTS. I already have stage 1 air and V&H slip ons. I plan on using a TTS map after the install. I am going on a run to Monterey next Friday and will not have time to dyno the bike. I have a couple of questions so that I dont f%&k up my ride between now and later; one, is the TTS map sufficient so that I should not need to dyno the bike. And two, how much more can I get out of the bike with a dyno run than the TTS map?
Any thoughts would be appreciated.
2011 FLTRX Vivid Black
Veritas et Aequitas
Martin is offline
post #2 of 6 (permalink) Old 06-02-2011, 04:29 PM
depends a really good job vtuning the tts should be within 5 or 10% of a really good dyno tune. I doubt you will do any damage. I would load the cal closest to what you have and run it for 20 miles and see how it feels. If it does not feel right you will know.
jeff is offline
post #3 of 6 (permalink) Old 06-02-2011, 04:32 PM
cestaro's Avatar
i have a call in to tts now wanting on a call back
but i used 1 of there maps no problem put now playing with vtune go to office max and print out the manuals it cost me $25.00 but its worth it i think ??????
cestaro is offline
post #4 of 6 (permalink) Old 06-02-2011, 05:11 PM
Ditto on printing out the manual. I read and reread it about 10X before starting and no way I could read like I wanted until it was printed.
jeff is offline
post #5 of 6 (permalink) Old 06-03-2011, 11:30 AM Thread Starter
Martin's Avatar
Thanks for the reply all! Getting a little anxious now to get the work done, do a test run, and then off to Monterey. Now all I have to do is pray the weather improves enough for a good ride.
Thanks again
Veritas et Aequitas
Martin is offline
post #6 of 6 (permalink) Old 06-25-2011, 05:33 PM
Not that everyone has this but. You can pull up the manual online. And i put it in my iBooks on both phone and iPad. Nice and handy to have as a reference.... I'm sure other smart phones can save the PDF for future reference.
Look through all the cal files. Pick the closest, go tune it... Then when you get time finish it with a good dyno operator
Hotpursuit is offline
New TTS Mastertune owner dnschmpn ECM/Fuel Management systems 9 10-20-2014 10:13 PM
TTS MASTERTUNE w/ Software and TTS USB cable. Raiderse Classifieds Archive (3 months old+) 0 05-17-2012 04:08 AM
TTS MasterTune Map to stop Ping and high heat 2011 RGU? Raiderse ECM/Fuel Management systems 15 05-10-2012 01:52 PM
TTS mastertune schuldtp ECM/Fuel Management systems 16 01-17-2012 08:24 PM
Get a great deal on TTS MasterTune BDMastiff Engine Related 35 05-28-2011 07:22 AM
