Help with Fuel Pak - 61019 - Road Glide Forums
post #1 of 26 (permalink) Old 06-11-2011, 12:21 AM Thread Starter
roadog28's Avatar
I just installed my pipes, intake and FP... I immediately noticed that when you quickly crack the throttle open and release, it chokes out/sputters/lags just a little bit. It's very brief, but you can tell that there is some sort of poor throttle response or something. Its significant enough that I actually stalled the engine at a stop light jacking with it... any thoughts? V and H is closed for the weekend. Thanks MIKE
2011 FLTRU, VH Pro Pipe HO, VH Stage 1, Fuel Pak
roadog28 is offline
post #2 of 26 (permalink) Old 06-11-2011, 05:29 AM
FrankieB's Avatar
Sounds like the accelorater (sp) pump setting is lean, but i can't remember if you can adjust that independantly with a fuel pak.
06 RK
11 RGU
FrankieB is offline
post #3 of 26 (permalink) Old 06-11-2011, 08:14 AM Thread Starter
roadog28's Avatar
Thanks for the reply. I'm going to call them Monday and see what they say. I was curious if it had anything to do with the throttle by wire set up? I'm not completely educated on how the TBW works, but I'm pretty sure there is a sending unit in the end of the handlebar that does the work. Keeping in mind that I don't recall having this issue before the install... is it possible that when I rolled my handlebars back (for comfort purposes) and adjusted the angle of the controls, that I somehow jacked up the "position" of the sending unit? Typing this out, it sounds pretty far fetched... but I thought I would ask.
roadog28 is offline
post #4 of 26 (permalink) Old 06-11-2011, 10:22 AM
joke's Avatar
Couldn't hurt to re-calibrate the FP in the new position. Reminds me I should do mine since I put on new bars.
2009 Mirage Orange
joke is offline
post #5 of 26 (permalink) Old 06-11-2011, 11:00 AM Thread Starter
roadog28's Avatar
Any thoughts on how to do that with the new FP and Throttle By Wire? Thanks MIKE
roadog28 is offline
post #6 of 26 (permalink) Old 06-11-2011, 02:44 PM
RIDERED67's Avatar
I just installed a Fuel pak on my 2011 with a vance and hines propipe and se air intake. Mine does the exact same thing as yours. Poor throttle response from closed throttle, almsot like a delay. It performs great in every other way and it even eliminated all of my pinging so I figured I would leave well enough alone. Please post the outcome of your discussion with Vance and Hines. If it happening to both of us Im sure everyone else is suffering from the same problem.
2011 Denim Black Roadglide
RIDERED67 is offline
post #7 of 26 (permalink) Old 06-11-2011, 04:26 PM
Boogitybob's Avatar
mine does same i've learned to give a little throttle at lights and roll on from there to avoid stalling but when i was using a friends model 61009 fuelpak with values for my 2011 it didn't have this lag and also still had O2 sensers connected don't know if there's any connection or not i also rolled my bars back but think that has nothing to do with it. I also noted that on a cold start up the throttle response is almost instantanious no lag
let us know what you find out thanks
BoogityBob
2013 FLTRU Vance and Hines Dresser duals,Monster ovals, VO2 naked intake, and Power Vision
Boogitybob is offline
post #8 of 26 (permalink) Old 06-11-2011, 04:55 PM Thread Starter
roadog28's Avatar
Well at least it's not just me!!! I already emailed tech support and will be calling them first thing on Monday. Thanks!!!! Mike
roadog28 is offline
post #9 of 26 (permalink) Old 06-13-2011, 09:15 AM
joke's Avatar
Hey Mike - what I'm going to do is disconnect and reconnect the FP module and then do the installation routine again, i.e., throttle roll, check the FP numbers - like I said I replaced my bars so things may have changed. But +1 on whatever V&H lets you know.
2009 Mirage Orange
joke is offline
post #10 of 26 (permalink) Old 06-13-2011, 11:25 AM Thread Starter
roadog28's Avatar
Spoke with Chris at V&H tech support. He stated that some of it could be riding style (not sure that applies here), but he did give me 3 modes to update. I will not be able to try this until later this evening, but wanted to get it out there in case anyone else has a chance.
Per Chris:
Update Modes 45, 46 and 47 all to 30.
I'm using map FP-4320 and it current has all those modes in the 20's.
Ill post my findings tonight!! MIKE
roadog28 is offline
Vance & Hines Fuel Pack # 61019 Peppa1 Parts for Sale 4 01-02-2014 05:49 AM
FuelPak 61019 blj9511 ECM/Fuel Management systems 6 02-11-2013 09:16 AM
WTB: V&H FuelPak #61019 blj9511 Wanted! (Buy or Trade) 2 02-02-2013 06:50 PM
Fuel Pak model # 61019 george liles Classifieds Archive (3 months old+) 4 07-29-2011 09:08 PM
Fuelpak 61019 For Sale roadog28 Classifieds Archive (3 months old+) 1 07-17-2011 05:14 PM
