tts starting calibration - Road Glide Forums
post #1 of 20 (permalink) Old 06-22-2011, 02:34 PM Thread Starter
FrankieB's Avatar
any recommendations for the base map to start with on 2011 bike with high flow air cleaner and two into one exhaust?
frankie
06 RK
11 RGU
FrankieB is offline
post #2 of 20 (permalink) Old 06-22-2011, 02:39 PM
BDMastiff's Avatar
I assume you're speaking of TTS MasterTune. Just call Steve at 310-669-8101. He's the owner/developer of TTS and will be able to give you the best advise.
1996 Fatboy
BDMastiff is offline
post #3 of 20 (permalink) Old 06-22-2011, 04:12 PM Thread Starter
FrankieB's Avatar
yes tts mastertune, i will call him if i run into trouble. I just wanted to see what maps other 2011 bike owners started with.
06 RK
11 RGU
FrankieB is offline
post #4 of 20 (permalink) Old 06-22-2011, 06:49 PM
cestaro's Avatar
if you have v tune with it it also comes with maps for different combs start there then you need to v tune it go to office max and print out mannual its worth it i can send you fullsac map to start with
cestaro is offline
post #5 of 20 (permalink) Old 06-24-2011, 06:18 PM
Are you going to use the mt8 files? Those are the newest.... I will look it up for ya
Hotpursuit is offline
post #6 of 20 (permalink) Old 06-24-2011, 06:28 PM
Cta009-03 is an mt8 file for 2010/2011 it's for a factory 2in1 exhaust and a/c
Ctc044-03 is an mt8 file for 2011 it's for a/c and a 2 in1 into 2 factory exhaust...
What 2 into 1 are you running. Either map will need vtuned for best results
post #7 of 20 (permalink) Old 06-25-2011, 03:45 AM Thread Starter
FrankieB's Avatar
i am running the 2 into 1 d&d boss cat. I got the base cal. (mt8 file) loaded in last night, now it is time to start the vtune process.
06 RK
11 RGU
FrankieB is offline
post #8 of 20 (permalink) Old 06-25-2011, 05:27 PM
Cool, if you need Anaya help just drop me a line....mt8 files have some nice new features.... Try to just focus on gathering enough info for ve tables.... This is most important. After that u can tweak the main lambda table take some areas out of closed loop...
Good luck
post #9 of 20 (permalink) Old 03-04-2012, 11:35 AM
12glide's Avatar
I will be installing Mastertune next week. I found a calibration that matches my modifications, except for the displacement. From what I've read I can change the displacement in the ECM constants from 96 to 103. Does anyone know the injector size on a 2012 103"?
12glide is offline
post #10 of 20 (permalink) Old 03-04-2012, 12:33 PM
what mods do you have?
jeff is offline
'18 114-in Stage=4 with TTS cams and TTS tuner Sharkbreath Dyno Results 12 12-16-2017 10:02 AM
calibration. pauld Troubleshooting for Road Glides 0 07-25-2014 09:22 PM
TTS MASTERTUNE w/ Software and TTS USB cable. Raiderse Classifieds Archive (3 months old+) 0 05-17-2012 04:08 AM
speedometer calibration? ameleo Do-IT-Yourself 6 03-04-2012 08:37 AM
Ecm calibration upgrade for 2007 big twins mea4dxl ECM/Fuel Management systems 3 11-18-2011 09:34 PM
