PC-V Map help - Road Glide Forums
post #1 of 4 (permalink) Old 06-24-2011, 12:54 PM Thread Starter
Luscruz's Avatar
PC-V Map help
2010 HD header 2 into 2, Cat removed with 4" Rineharts and Ness Big Sucker.
Does anyone have a map for this setup. Fuel Moto sent one but it will not open. I plugged in a map from PC of something similar, runs good but may be to rich.
Thanks
Mason
Luscruz is offline
post #2 of 4 (permalink) Old 06-24-2011, 02:44 PM
Moderator
gkt33's Avatar
Send a message via Yahoo to gkt33
you may as I had to do obtain a map from 2009 since you've had the cat removed. give them a shout and see what they say. They found the closest to what I had.
"SMOKEY"
gkt33 is offline
post #3 of 4 (permalink) Old 06-24-2011, 05:41 PM Thread Starter
Luscruz's Avatar
Did you contact the power commander folks for your map ?
Luscruz is offline
post #4 of 4 (permalink) Old 06-25-2011, 10:03 AM
Moderator
gkt33's Avatar
Sure did. They are very helpful.
"SMOKEY"
gkt33 is offline
PC-V Map Needed for V&H Set-up Agent Joe Map Section 5 12-08-2012 05:59 AM
PC-V Base Map needed Hullhorr Map Section 0 10-22-2012 01:20 PM
pc iii map needed 07 deluxe with 48cam bigpete1 Map Section 1 06-25-2012 07:53 AM
Looking for PC V map sftosendai Road Glide Specific Discussions 0 06-14-2011 11:23 PM
Map for PC III USB for 06 RG kimmer127 ECM/Fuel Management systems 2 10-15-2010 03:18 PM
