Temp 255 - Road Glide Forums
post #1 of 20 (permalink) Old 10-12-2013, 07:05 AM Thread Starter
SmokeyJoe's Avatar
Temp 255
Today i autotuned my bike with the Power Vision. The bike is running great, the other other mod are the CFR slipons. My gas milage is in the low 40's and on the highway running 70 it stays around 55mpg. Only issue i see are the temps are around 255f
Any ideas?
SmokeyJoe is offline
post #2 of 20 (permalink) Old 10-12-2013, 11:51 AM
Boatnut's Avatar
temps
If that's the oil temp, yeah that's high. If that's the head temp it's about where mine runs. I called Jamie and he told me normal range would be 260-310 degrees on my 103 , his ceramic coated head pipes and his slip ons with a big sucker AC. I put the PV on before these mods and it now runs approx 40degrees cooler than used to stock. I'm getting 46mpg two up mixed riding and have seen 51mpg one up cruising at 60mph.
Boatnut is offline
post #3 of 20 (permalink) Old 10-12-2013, 12:03 PM
moose1's Avatar
Man I have to ask how in the heck are you guys getting that kind of fuel mileage my 12 RGU with decatted head pipe stage 1 and CFR slip ons and now the fi2000 cobra AT I'm still only looking at 30 mpg with the tour pack off
Sent from Motorcycle.com App
2012 FLTRU vivid black
moose1 is offline
post #4 of 20 (permalink) Old 10-12-2013, 12:13 PM
Triplej's Avatar
Moose, ya gotta keep the front wheel on the ground if you want to bust the 40 mpg mark
Triplej is offline
post #5 of 20 (permalink) Old 10-12-2013, 01:15 PM Thread Starter
SmokeyJoe's Avatar
Yes i was surprised myself, cause i was tearing it up for more than a 100 miles trying to get all of the hits on the PV. And i really started liking the 4K sound.
post #6 of 20 (permalink) Old 10-12-2013, 01:21 PM
h-donut's Avatar
+1
backing down into the power band can be just as effective
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #7 of 20 (permalink) Old 10-12-2013, 04:32 PM
thedrill's Avatar
I am getting "last time I checked" 38mpg on my 12 RGU and I am NOT light on the throttle. I weigh 220 and have a 1/2 mile steep hill on the way to work I always reach 75 to 80 mph climbing it. I am running all stock but a fullsack sportpipe and SE air cleaner with a V&H fuel pack. I run 80MPH everywhere I go out here in the desert. When I drive the speed limit it is a solid 42 MPG
2012 Road Glide Ultra, 1978 Honda XL125, 1992 Suzuki DR350
thedrill is offline
post #8 of 20 (permalink) Old 10-13-2013, 05:40 PM
moose1's Avatar
I wish I could but these things just like to go fast even though I really don't care about the mpg except when I take long trips it's just crazy how good some of them get.
moose1 is offline
post #9 of 20 (permalink) Old 10-13-2013, 06:19 PM
Gonekat's Avatar
I would say your temp problem is cause by the great fuel economy. the fuel cools the engine as well as power. My temps went down after stage one, but so did my fuel economy. Just a thought.
2011 RGC, Sedona Orange 103" w/ 48H cams,PM Icon 21" wheel,Kury Mach 2 intake,Jackpot 3.5, PM brake and shift levers, CB 14" TRSSC shield, Sinister 14" apes, custom levers.Black exhaust,floorboards,pegs and crash bar.
Gonekat is offline
post #10 of 20 (permalink) Old 10-13-2013, 07:11 PM
Gibson's Avatar
I was getting the same as you with the Cobra, switched to the PV and mpg has been in the 40s ever since
Gibson is offline
Engine oil temp? At what temp do you pull over? Mountainman Fluids and Lubricants 35 07-07-2015 03:47 PM
CVO 255 cams (AKA SE-255) cams pat123 Parts for Sale 3 07-26-2013 08:58 AM
07 103" Roadglide, Stock Heads, 255's hdxbones Dyno Results 24 10-13-2012 01:10 PM
255 cam install jbennett74 *General Road Glide Discussions/Pictures 5 04-22-2011 03:22 PM
Andrews 26 vs. SE 255 SLOglide Engine Related 5 03-15-2011 05:54 PM
