Another PV Question - Road Glide Forums
post #1 of 4 (permalink) Old 10-19-2013, 09:54 AM Thread Starter
Another PV Question
I'm getting an up-shift pop, only sometimes, from 2nd to 3rd. I've seen other threads about upshift popping. How do I know if it's the map or loose exhaust flange???
I didn't do it originally when I uploaded my map from Jaimi. Just started and like I said is only sometimes. I can almost make it do it buy loading the exhaust by not letting off the throttle soon enough when I clutch.
Does anyone know what torque the exhaust should be tightened to? Or should I just replace the gaskets? If so, what gaskets?
I had a friend with a street glide running a Dragula and was getting a lot of upshift popping. Everyone kept telling him exhaust leak and he tightened his exhaust so much he had to have the bolts drilled out later to replace the gasket.
Halstem1 is offline
post #2 of 4 (permalink) Old 10-19-2013, 10:58 AM
Crazylegs's Avatar
Try a different map and see how the pop is affected. If it helps, compare the maps in the decel area. To check for exhaust leaks, I used a birthday candle and the crossover under thr bike blew it out.
Crazylegs is offline
post #3 of 4 (permalink) Old 10-19-2013, 02:09 PM
skratch's Avatar
the torque on the exhaust header bolts is not very high.
on the front cylinder, you tighten the top nut to 9-18 in/lbs, then tighten the bottom nut to 100-120 in/lbs and then go back and tighten the top nut to 100-120 in/lbs.
the rear cylinder uses the same specs, only you start with the bottom nut first.
skratch is offline
post #4 of 4 (permalink) Old 11-06-2013, 08:30 AM
joe_lyons50023's Avatar
Lower the decell enleanment by %20 and see how it does.
joe_lyons50023 is offline
PV software question: Where is my original map downloaded to on the computer. batman825 ECM/Fuel Management systems 4 04-06-2017 02:32 PM
Jaimi - PV question - Up-Shift Pop Halstem1 Fuel Moto 5 12-03-2013 08:15 AM
Pv,rineharts,2-1-2 fuel moto are shipped Jesse_the_kid Intake and Exhaust 2 04-20-2012 07:52 AM
PV question? roaddog ECM/Fuel Management systems 2 02-24-2012 07:03 PM
