Power vision Problem - Road Glide Forums
post #1 of 17 (permalink) Old 10-21-2013, 12:53 PM Thread Starter
Question Power vision Problem
This problem is occurring more frequently and I was wondering if anyone else has had similar experience. While riding the data on my PV will stop steaming and data fields will go blank. There is still power to the unit just no data displayed in the boxes. The unit will not respond to any button pushes. I have to turn the ignition switch to off then back on and it has reset and worked every time. Which leads me to believe it is not a loose connection. This is starting to happen more often and I am concerned that eventually it will not come back on. Any help with this would be Greatly appreciated.
2013 FLTRX, FM Jackpot 2-1-2 , FM A/C, 4" Rineharts,PVw/Autotune, Arlen Ness deep cut hot Legs, Progressive mono, Detach Tour Pak, 14" Windvest, Buky 12" Malo, JM XTs and AMP
twrguy is offline
post #2 of 17 (permalink) Old 10-21-2013, 01:09 PM
tdkkart's Avatar
How do you have the cable routed to the data plug?? Tucked up under the tank, over teh top of the tank under the dash or under the tank through the wiring channel??
Many people have had trouble with EMI interference when simply tucking the wiring up under the tank. Interference from the ignition system will cause the PV unit to lock up.
tdkkart is offline
post #3 of 17 (permalink) Old 10-21-2013, 04:55 PM
Boogitybob's Avatar
I have mine tucked under council no problems at all That is if I can ever get rid of pinging
BoogityBob
2013 FLTRU Vance and Hines Dresser duals,Monster ovals, VO2 naked intake, and Power Vision
Boogitybob is offline
post #4 of 17 (permalink) Old 10-21-2013, 05:14 PM
Had mine in the wiring channel and it would do it all the time moved it over in the channel and now it hasn't done it since .
cbumdumb is offline
post #5 of 17 (permalink) Old 10-21-2013, 05:38 PM
mocotom's Avatar
Do you have the knock retard feature enabled? PV will identify the area where ping occurs and reduce timing to eliminate the ping if you program it to do so.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #6 of 17 (permalink) Old 10-21-2013, 10:06 PM
Boogitybob's Avatar
yes I have it enabled but no luck after doing auto tune I can see no changes to timing numbers when I look at map of tune session
BoogityBob
post #7 of 17 (permalink) Old 10-21-2013, 10:33 PM
Crazylegs's Avatar
I used log tuner to clear up all the knock events. Once you get on to it, its quick and easy to retard the timing in the ping areas.
Crazylegs is offline
post #8 of 17 (permalink) Old 10-22-2013, 08:09 AM
mocotom's Avatar
You will need the Powervision set to the "Pro" feature in WinPv software if it is not already. After changing to the PRO mode go back to the bike and now when you choose AT, press the settings tab. A list of options appears, scroll to "max spark learn" and set it to 10. Enable the AT and ride in the conditions you normally experience the ping, the PV will log and reduce the timing in affected areas. Down load the AT session to the ECM and your done. If the ping is severe, it may take more than one AT to correct.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #9 of 17 (permalink) Old 10-22-2013, 03:06 PM Thread Starter
Thanks
I currently have my cable running in the backbone, I will see if shifting it makes a difference. If that doesn't work I will run it under console.
Thanks again for the help guys!!!!
twrguy is offline
post #10 of 17 (permalink) Old 10-22-2013, 03:09 PM
PGR
PGR's Avatar
I have mine run under the console....... maybe lazy is not such a bad thing
Ron..........................
PGR is offline
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 02:37 PM
Power Vision problem Hack73 ECM/Fuel Management systems 30 05-03-2017 10:59 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
New tuner from Dynojet - "Power Vision" 4getNo1 ECM/Fuel Management systems 103 10-30-2012 05:25 PM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 07:21 AM
