Misled on exhaust, advice - Road Glide Forums
post #1 of 11 (permalink) Old 07-11-2011, 09:32 AM Thread Starter
Hope someone can give me advice:
I bought my 06 RG used, and was told it had the D & D Fat Cat; just found out it is the Boarzilla. Love the exhaust system, just wondering if it will cause issues in the long run; I'm running a KN airfilter and the bike was mapped prior to me owning it; haven't had any issues to date just a little popping on rapid decelleration.
Thanks in advance
newtome is offline
post #2 of 11 (permalink) Old 07-11-2011, 09:48 AM
As long as the bike is running good you should not have any problems. What kind of tuner does the bike have? If everything is done right the bike should not have any popping on decel, there are basically 2 conditions that cause popping on decel and they are 1. the bike does not have the correct fuel mapp and 2. there is a leak in the exhaust somewhere. The most common place for a exhaust leak would be at the cylinder were the exhaust pipe bolts on but a exhaust leak can happen anywhere the exhaust system has a connection.
post #3 of 11 (permalink) Old 07-11-2011, 09:52 AM Thread Starter
There is no tuner, an indie flashed it. I am looking at purchasing a Thunder Max in the future.
newtome is offline
post #4 of 11 (permalink) Old 07-11-2011, 10:02 AM
There are a lot of tuners out there so do some research before buying. I use the HD Screaming Eagle Race Tuner more commonly known as the SERT and I am very happy with it.
post #5 of 11 (permalink) Old 07-11-2011, 11:27 AM Thread Starter
Thanks for the advice, do you need to go the dealer to tune the SERT?
newtome is offline
post #6 of 11 (permalink) Old 07-11-2011, 11:40 AM
Yes you do. The dealer will put in the correct fuel mapp according to your add ons. Once the tuner is set then you don't have to make any changes until you do some more engine work such as cams but that will happen with any brand of tuner. The dealer will also use the SERT to do a dyno tune. I had my bike dyno tuned in the last part of 08 and never had to touch it again. You really don't need to dyno tune your bike unless you have performance engine work done.
post #7 of 11 (permalink) Old 07-11-2011, 11:43 AM
Moderator
BLKNCr6's Avatar
I use the Screamin' Eagle Pro Super Tuner, which I believe replaced the Race Tuner. I love mine. It has forced me to start learning about what makes these bikes make noise...and the education has been a blast.
The Street Tuner is dealer flashed. The Pro Tuner has cables and software available for you to flash...I think I have that correct...
I flash mine about weakly as I learn and get more recorded runs done. Working off a base map set on the dyno.
...and I used to think my Sportster was heavy...
A Harley will get you through times of no sex, better than sex will get through times of no Harley.
2011 FLTRU
SE Heavy Breather
V&H Monster Ovals
SE Pro Super Tuner to make the above play nice together.
BLKNCr6 is offline
post #8 of 11 (permalink) Old 07-11-2011, 12:42 PM Thread Starter
Ironmark and BLKNCr6, thanks for the info and advice, i will keep that in mind. Our closest dealer is an hour away and the better one is almost 2 hours away. The indie is in good with the one 2 hours away so I will see what he can support at his shop as well.
newtome is offline
post #9 of 11 (permalink) Old 07-11-2011, 02:13 PM
zman's Avatar
When I got my pre-owned 06 it had stage 1 intake, SE slip-ons and had a map flashed at the dealer. It ran well but only got about 35 mpg. I hooked up with Fuel Moto (they are one of our forum sponsors). They deal with power commander and have a version of their own which I bought. I am very happy. They will modify the map as you request. I called and asked for a leaner map and it was e-mailed to me immediately. Loaded it to the tuner and all is good 45 mpg now and plenty of zip. If you are popping on decel, I wonder if your a little rich.
"I Just Cant Leave Well Enough Alone"
zman is offline
post #10 of 11 (permalink) Old 07-11-2011, 02:39 PM
That's a big pipe for an 88, so was the engine hopped up extensively, Bigger pistons? Cams etc?
Boarzilla was the only pipe I found that would mount right up to my 124 heads without
problems, it's made for big engines...
Probably won't hurt and not worth dropping a lot of coin to change it to a fat cat..
"My rule of life prescribed as an absolutely sacred rite smoking cigars and also the drinking of alcohol before, after and if need be during all meals and in the intervals between them." Winston Churchill
Hotroadking is offline
Advice wanted for new exhaust 2015 RGS Jhl192 Intake and Exhaust 8 10-26-2015 02:19 PM
Exhaust questions? Need advice Hd2500407 *General Road Glide Discussions/Pictures 6 07-12-2011 11:49 AM
Misled on exhaust, advice needed newtome Intake and Exhaust 0 07-11-2011 09:50 AM
