V&H fuel pak - Road Glide Forums
post #1 of 3 (permalink) Old 07-12-2011, 04:55 PM Thread Starter
BklynRGU's Avatar
V&H fuel pak
i have a 2011 rgu and have a buddy giving me a fuel pak part#61009
i called V&H and they said it will work but its better to buy the 2011 model because its made just for that year model.what do you guys think.the guy sounded more like a seller than a tech.he said you get better results with 2011 model.also im thinking of cutting out the baffles out of my stock exh.i saw a 2011 rg w/103 it sounded very nice i thought he had rineharts until he showed me they were stock exhaust.but he did chage the filter and put a
pc-v.he said his dad didnt and ran fine.
BklynRGU is offline
post #2 of 3 (permalink) Old 07-12-2011, 05:22 PM
I emailed VnH a few days prior to buying my fuel pak, knowing that a map for my setup will not be on the list they have packaged or on their site. Gutted oem header, Carriage Works slip on, XIED,..etc I received an email within 2 days of a recommended map. Spot on, pulls harder in the upper revs, runs cooler. Email them for a map with your intended setup and try it out first, my 2 cents
2010 FLTRX VB
Autobred is offline
post #3 of 3 (permalink) Old 07-13-2011, 04:39 AM
ltdannyboy's Avatar
Sounds like a sales pitch to me. They should have a map for you.
ltdannyboy is offline
V&h fuel & throttle pak BklynRGU Parts for Sale 4 11-20-2014 08:14 AM
Fuel Moto 107" hi output R&D motor 151Hp Pump Fuel fuelmoto Dyno Results 5 01-22-2014 07:24 PM
Fuel motto or V&H fuel pack thedrill ECM/Fuel Management systems 15 09-26-2013 09:40 AM
Magnetti-Morelli Fuel Injection with V&H Fuel Pack emorris ECM/Fuel Management systems 5 10-08-2012 10:17 AM
Throttle Pak Versus Fuel Pak Bodyarmorguy ECM/Fuel Management systems 6 02-24-2012 09:17 AM
