Who is using Thundermax?? - Road Glide Forums
post #1 of 15 (permalink) Old 10-26-2013, 11:35 AM Thread Starter
thedrill's Avatar
I was wondering if the thundermax was worth the 999 they want. Is anyone out there using it? And what are your experiences with it? All comments appreciated.
2012 Road Glide Ultra, 1978 Honda XL125, 1992 Suzuki DR350
thedrill is offline
post #2 of 15 (permalink) Old 10-26-2013, 12:42 PM
tsmartt's Avatar
Yes it is worth it if you are going to build your engine. Works great with a staged build. Check with Drago's Bike Works for a better price. He is a site sponsor and has other awesome products. Good luck.
Quattro / 16 RGS / Dragula2 2:1 / Drago 565 / ThunderMax Tuner / Fuel Moto Breather / Klock Werks Flare / Custom Dynamics LEDs
Orange Crush / 13 RGC / Dragula 2:1 / TMan 555TQ / ThunderMax Tuner / Zipper's Max-flow Breather / Klock Werks Flare / Custom Dynamics LEDs
tsmartt is offline
post #3 of 15 (permalink) Old 10-26-2013, 12:43 PM
Bluchevypick's Avatar
I run it on my bike. Have never had an issue with it. Plug it in, put base map into it and ride. Might not make the most power with it but it has given me a smooth power band with my old setup. Havent had the new setup tuned yet to see.
Bluchevypick is offline
post #4 of 15 (permalink) Old 10-26-2013, 01:15 PM
PFWiz's Avatar
I installed my TM when I did my stage 1. No dyno needed just loaded a close map and let it do its thing.
When I added a TMan 555 tq cam last winter same story. Loaded a close map and let the TM do it's thing.
The bike runs great with no pinging or popping. I got a map made a dyno shoot out this summer. Nice smooth lines with numbers equal to what 90% of the folks are posting. I get about 43 mpg at 65 with the cruise on and less when I am feeling froggy.
Once every 1000 miles or so I get my laptop and up load the map from the TM to see what changes it has made and to make sure everything looks ok. If I like it (I have never had a problem) I accept the changes and download it back to the TM to be the new baseline map.
I also used the TM to calibrate my speedo. It now reeds within 1 mph of my GPS.
+1 on talking to Drago. He has good prices and is the king of performance.
PFWiz is offline
post #5 of 15 (permalink) Old 10-26-2013, 03:06 PM
I'm on my second bike with the TMax, I love it, works great. As mentioned talk to Frank for a much better price.
Sent from my SPH-L710
post #6 of 15 (permalink) Old 10-26-2013, 05:01 PM
Bruckus's Avatar
I bought mine from Frank. It was preloaded and plug and play. Easy to install and so far trouble free. I am not much for messing with maps so I left it up to Dragos for the setup and I just ride. I won't put words in Franks mouth but we discussed what I needed, the differences in other tuners and with his input I decided on the ThunderMax. If I do upgrades down the road I'm good to go.
2013 Roadglide Custom - Candy Orange
Drago's Dragula True Duals, Thundermax Tuner
Daymaker LED Headlights, Supershox
Bruckus is offline
post #7 of 15 (permalink) Old 10-26-2013, 05:47 PM
Q-Hog's Avatar
Got mine from Frank as well. Once you learn the process it's a great.. You can update & auto-tune as frequent as you want..
Q-Hog is offline
post #8 of 15 (permalink) Old 10-26-2013, 07:10 PM Thread Starter
thedrill's Avatar
Thanks for your input. I may do a stage 4 kit this winter if the $$ are there. I think I will do it. I have a fullsack sportpipe on my bike now. It has stock 2012 O2 sensors. will the thundermax 02 sensors fit? Or do I need bigger bungs.
thedrill is offline
post #9 of 15 (permalink) Old 10-26-2013, 07:14 PM
The thundermax uses 18mm bungs. If you buy the thundermax new it will come with the bungs and you can have them welded in
post #10 of 15 (permalink) Old 10-27-2013, 10:38 AM
I got the T-Max and it is a great product IMO. I got mine from Frank too, great price. You need the 18mm O2 bungs for the closed loop O2 sensors and the closer the 18mm O2 sensors are to the cylinder heads the better it works, you can either weld in the bungs or get new head pipes. The 2009 head pipes have the 18mm bung and they are in the correct location and the 2009 head pipes will work on all 2009 to 2013 touring models, some aftermarket head pipes come with both the 12mm and 18mm O2 bungs so pay attention if you buy new head pipes if they offer 1 or 2 O2 locations.. The only down side that I found with the T-Max tuner is if you have a problem with the tuner or the tune the only way to communicate with customer support is by E-Mail, you can't talk to a live person which kind of sucks.
Anyone using an E-Z Pass? philmartin General Off-Topic Discussions 34 01-23-2012 11:24 AM
Anyone using SE Pro Super Tuner? Wharf Rat ECM/Fuel Management systems 6 04-22-2011 09:15 PM
What Bike Cover are You Using??? DUBB *General Road Glide Discussions/Pictures 14 03-20-2011 01:18 PM
Any one using the Pandora App on the iphone with the radio? zuppy51 Aftermarket Accessories 11 11-06-2010 07:02 PM
Anyone using 16 or 18" bars on a RG Sim Controls & Handlebars 9 10-19-2010 09:03 AM
