Power Commader V - Road Glide Forums
post #1 of 7 (permalink) Old 11-01-2013, 10:52 AM Thread Starter
Power Commader V
When hooking up an auto tune to it do I need to change anything about my O2 sensors, or do I just plug in the sensors that I disconnected installing the PC5?
2013 FTLRX, stock head pipe with cat removed. Thanks guys.
BigWaterJim is offline
post #2 of 7 (permalink) Old 11-01-2013, 12:41 PM
mocotom's Avatar
The auto tune for your PCV will use wide band O2 sensors. They require 18mm bungs in the head pipe mounted 2" to 4" down stream from where the pipe meets the cylinder head. If you don't have these bungs you can have them welded in at most any muffler shop or purchase a different header that comes with the 18mm bungs already installed.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #3 of 7 (permalink) Old 11-01-2013, 01:31 PM Thread Starter
Thanks tom. I will install the PCV myself, do I just down load a stage 1 into it?
Is the auto tune worth it? Also does temps make a difference as I will ride most of the yr in the NE. Thanks.
post #4 of 7 (permalink) Old 11-01-2013, 04:29 PM
laxinharley's Avatar
Jim temps don't matter. It what I have and I've ridden from 32 degrees to 101. No problems. With my pC5 it was very easy. Hook up to the computer pick your components and done. Hook to the bike and try it out
laxinharley is offline
post #5 of 7 (permalink) Old 11-01-2013, 05:14 PM
mocotom's Avatar
If you have a stage 1 or mild build, you should be fine with a download. If you buy the PCV from Fuelmoto they will pre-load a map for what you have done to the bike. They have great customer support.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #6 of 7 (permalink) Old 11-01-2013, 06:32 PM Thread Starter
Got it slightly used. No map in it now. When it comes I will have to config. Thanks men.
post #7 of 7 (permalink) Old 11-07-2013, 06:57 PM Thread Starter
Installed my PC V today. Took all of 20 mins to download a map and install on bike. Tomm morn SE intake with Zippys filter. This is the 1st bike I have been working on. Always paid someone before. Thanks for all the post men.
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 02:37 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
Commader II tire pressures? baldwookie Wheels and Tires 10 04-17-2013 09:07 AM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 07:21 AM
Power Commander V and Big Sucker Air Cleaner The Infamous Sharknose Equipment-RG 0 09-18-2009 10:07 AM
