Thundermax questions - Road Glide Forums
post #1 of 6 (permalink) Old 11-07-2013, 03:33 PM Thread Starter
Rusty one's Avatar
I installed the Thunder Max with auto tune on my 09 SG. Looking to change out my exhaust but cant figure out how to disconnect the wire from the 02 sensors...seems there's some sorta clip on each end of the wire..
Any trick of getting it apart so I can unscrew each sensor?
Thx!!
Rusty one is offline
post #2 of 6 (permalink) Old 11-07-2013, 03:56 PM
faststan's Avatar
Follow the wire to a junction block. If it's like the 11 it is under the right side cover. That's where you disconnect.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 6 (permalink) Old 11-07-2013, 03:57 PM
eme56's Avatar
The leads for the sensors are 12-18" long. The plug for the front will be under the frame near the transmission. The rear plug was probably routed around behind everything and coiled up near the T-Max itself. The clips you are talking about are part of the plug assembly. Take a close look at it when you have cut the wire ties and have some slack to play with. It is not real obvious where the plug comes apart. Look for the 2 locking tab holders on the computer side of the plug. Then you will see the tabs inside them. 80% of the plug is on the O2 side, not the computer side. Using a very small screw driver you can release them one at a time and work the plug apart. It's real obvious once it's apart but hard to see when plugged together. Hope this helps.
2005 FLTRI Black Cherry, 95" Big Bore, Thundermax w/Auto Tune, V&H Dresser Duals w/Klock Werks SS, Andrews 26 Cams, SE Stage 1 intake, SE OD/6 Speed, Wards FCS cooling fans, Krome Werks Stretch Heritage +2 bars, Progressive Monotubes, 444's, & Touring Link, Michelin Commander II's, 14.5" Madstad, Lowers with Classic Motorcycle Vents, detachable King Tour Pack, Daymakers
eme56 is offline
post #4 of 6 (permalink) Old 11-08-2013, 12:37 AM Thread Starter
Rusty one's Avatar
No problem where the plug ( connection) is...its trying to pull the plug apart..
I'll check and give your suggestion a try...thx!!
post #5 of 6 (permalink) Old 11-08-2013, 12:16 PM
Hullhorr's Avatar
They can be difficult to pull apart. There is a tab you need to depress while pulling the two halves. Do the rear one first as it is easier to see. Look for the tab and depress while pulling. When you reassemble be sure to use dielectric grease.
2009 FLTR MOP
Hullhorr is offline
post #6 of 6 (permalink) Old 11-08-2013, 07:37 PM Thread Starter
Rusty one's Avatar
Thank you for the info...will check and see how it goes this weekend!
Thundermax TBW MakeARunMike ECM/Fuel Management systems 15 06-01-2011 10:07 AM
Thundermax on a stock 2010 RGC pab ECM/Fuel Management systems 18 12-22-2010 04:25 AM
Thundermax impression Rowdy ECM/Fuel Management systems 9 11-23-2010 09:27 PM
thundermax TBW roadgliderick ECM/Fuel Management systems 0 11-23-2010 12:36 AM
Zipper Thundermax Ranger58 ECM/Fuel Management systems 12 11-19-2010 10:26 AM
