Power Vision "Fuel Trim Values"? - Road Glide Forums
post #1 of 11 (permalink) Old 11-09-2013, 03:40 PM Thread Starter
bear25314's Avatar
I'm on a 2013 Road Glide Custom. I added CFR's and also a Power Vision from Fuel Moto. I uploaded the custom map into the ECM. I then took her out for a ride and used Auto Tune. When uploading the auto tune it asks if I want to change "Fuel Trim Values". I answered "no". Was that correct? When would I want to change that?
bear25314 is offline
post #2 of 11 (permalink) Old 11-09-2013, 03:47 PM
rageglide's Avatar
You sure it didn't say, Do you want to reset Fuel trims? It's normal to see that when loading a tune, and you should almost always say Yes. The only time you might not reset them is if you'd made a change to something minor and were reflashing the same tune, ie, bumping rev limiter up.
You can reset trims now without reflashing, either that reflash and say Yes to reset them. Then run an auto tune with the new tune you got from FM.
2012 fltrx
rageglide is offline
post #3 of 11 (permalink) Old 11-09-2013, 04:46 PM Thread Starter
bear25314's Avatar
Thanks! So should I re-flash the original map Fuel Moto gave me and then Auto Tune again saying "yes" or should I just Auto Tune again and answer "yes"?
post #4 of 11 (permalink) Old 11-09-2013, 06:26 PM
tdkkart's Avatar
The fuel trim values are the fine adjustments the ECM does to the VE table to more closely zero in on the desired fuel mixture. The VE values that are developed by the autotune are the "course" adjustments, the trims are a "fine" adjustments that are dynamic, ie they change all the time.
So, when you flash a new tune you should clear out the trim values.
You can reload the autotune that you just did, and then clear the trims. You can reset them anytime on the trip screen, which I do sometimes when I switch back and forth from ethanol to non-ethanol.
tdkkart is offline
post #5 of 11 (permalink) Old 11-09-2013, 06:41 PM Thread Starter
bear25314's Avatar
Oh, ok. Got it. Thanks so much!
post #6 of 11 (permalink) Old 11-10-2013, 12:47 PM
rageglide's Avatar
What TDK said!
Also, you will want to run through the autotune process a few times, commiting changes after 30-40 minute tuning rides. You will want to reset the trims when you reflash the ECM with the committed autotune map. The goal is to get the VE tables to a point where you don't see huge changes after applying the changes. You can validate the changes by loading the your maps into WinPV and doing a compare between maps.
2012 fltrx
post #7 of 11 (permalink) Old 11-10-2013, 03:48 PM Thread Starter
bear25314's Avatar
Originally Posted by rageglide View Post
What TDK said!
Thanks again. I have done 4 auto tunes. Reworking the prior tune every time. I am amazed how easy it is to auto tune and then load the new tune into the bike and I can really feel and hear how well the bike runs. More power, no decal popping, no flat spots. I'm very happy with the Power Vision and CFR's. Now I have to decide on a new AC. Thanks for all the help with this.
post #8 of 11 (permalink) Old 11-11-2013, 09:30 AM
EFI tuning and Exhaust Expert
fuelmoto's Avatar
Also note every time you enable Auto Tune that PV resets fuel trims automatically
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #9 of 11 (permalink) Old 11-24-2013, 07:47 AM
Originally Posted by tdkkart
You can reset them anytime on the trip screen ...
Okay, what exactly does that mean? "trip screen"?
Budro is offline
post #10 of 11 (permalink) Old 11-24-2013, 08:37 AM
Trip screen shows miles and fuel mileage trip a and trip b
2013 RGU, black of course....
y2kflhr is offline
Torque values for 2015 Road Glide front end kws15off Wheels and Tires 2 07-24-2017 07:26 PM
2015 Shark=bad values for ours DOOFUS *General Road Glide Discussions/Pictures 103 12-24-2014 10:53 AM
Bike Values srs64 General Off-Topic Discussions 17 05-27-2012 01:14 AM
Tourque Values??? Ernster500 *General Road Glide Discussions/Pictures 3 05-08-2012 09:05 PM
Torque Values lldsilver41 Troubleshooting for Road Glides 3 01-23-2011 07:27 PM
