Power vision tune - Road Glide Forums
post #1 of 16 (permalink) Old 11-23-2013, 05:32 PM Thread Starter
Power vision tune
I have a 2013 with cut out cat, Rinehart slip-ones, screaming eagle intake and just bought a PV-1 unit. I install a tune for S&S with air filter upgrade and it's ok, but not right. Does anyone know of a tune that would get me closer? I was going to call vendor but ran out of time yesterday. It's cold outside, so I got time on my hands to re-tune, but don't know which one to use.
Harleyglide2013 is offline
post #2 of 16 (permalink) Old 11-23-2013, 05:35 PM
PGR
PGR's Avatar
Try doing a few autotune runs to tweek the canned tune.
Ron..........................
PGR is offline
post #3 of 16 (permalink) Old 11-23-2013, 05:36 PM
faststan's Avatar
Do an 'auto tune'. The PV has the ability to do a 'Basic Auto Tune' while riding your scooter. Start the Basic Auto Tune, ride for a while the way you normally ride, save the tune and then download the tune you just saved.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #4 of 16 (permalink) Old 11-23-2013, 06:07 PM Thread Starter
Do you know if removing the cat, but staying with stock O2 sensors changes anything on the can tunes?
Will the auto tune pick this up and fine tune the bike based off any tune that's close?
post #5 of 16 (permalink) Old 11-23-2013, 06:45 PM
faststan's Avatar
You must have the O2 sensors to run the PV. It's part of the puzzle.
faststan is offline
post #6 of 16 (permalink) Old 11-23-2013, 07:18 PM
mocotom's Avatar
If the canned tune is close it will get better with auto tune basic which uses the stock 02 sensors.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #7 of 16 (permalink) Old 11-24-2013, 10:13 AM Thread Starter
Thank you! Once it warms up I will take it out and run the autotune.
Next question: I do not plan on mounting the unit to the bike. Just get it where I want it and then remove the unit. BUT if someone has come up with a great mount that is not real noticeable when not on bike, please share!
post #8 of 16 (permalink) Old 11-24-2013, 10:48 AM
tdkkart's Avatar
Yes, having the cat removed will make a large difference in the tunes that are listed for the stock header. The cat changes the reversion characteristics of the pipe, which then changes what the o2 sensors see.
The TechMount from FuelMoto works great and would be very non-obtrusive if the PV Unit is removed I have mine permanent mounted to the bars just to the left of center.
http://www.fuelmotousa.com/harley/ac...s/3-30912.html
tdkkart is online now
post #9 of 16 (permalink) Old 12-05-2013, 01:33 PM
Xaran's Avatar
Run the basic auto tune. As long as the bike is close with the canned MAP you have it will get better with a few data runs. its very easy to do now that the firmware is in the PV. Just follow the screen directions. Ride it at all speeds and rpm, get some pulls in on a hill ect. at least 20 min of riding. then save and flash the new tune and do it again. I had to run 4 to get it to where there were almost no changes in the tune. so dont be afraid to repeat the data runs a few times and build off each new tune.
if you got the unit from Fuel Moto , call them for info, Jamie walked me through the process a few years ago and was very helpful
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
post #10 of 16 (permalink) Old 12-05-2013, 08:58 PM
smitty901's Avatar
Mounting the power vision allows you to use the many features it has built in to it.
Not just a tuner.
couple examples
smitty901 is offline
My Power Vision Auto tune results. LL Cool K ECM/Fuel Management systems 137 06-06-2017 05:15 PM
First ride after Power Vision tune... ChromeYellow67 Fuel Moto 19 01-14-2014 12:54 PM
Power Vision Auto Tune ? otis2013 ECM/Fuel Management systems 3 04-04-2013 07:23 PM
Question 4 you Power Vision pro auto tune guys - kinda long landshark ECM/Fuel Management systems 2 03-12-2013 06:21 AM
Power Vision basic Auto tune or Pro? baldwookie ECM/Fuel Management systems 8 03-02-2013 09:15 AM
