Better options for fuel management? - Road Glide Forums
post #1 of 7 (permalink) Old 08-10-2011, 12:18 PM Thread Starter
bvanlente's Avatar
Hi I have a 2011 with the smaller diameter O2 sensors. Everything I find seems to use the 18 mm sensors, requires a dyno or constant tweaking of maps. I thought Thundmax was the ticket until I learned I needed to plug the existing 12mm holes and drill the head pipes for the larger diameter holes and then buy the the larger 18mm O2 sensors. Is there not a product that self tunes and uses the existing O2 sensors...that actually works? I just want performance out of the box and I don't want to be tweaking to make my bike run correctly.
Flame away on me but I just want to ride.
bvanlente is offline
post #2 of 7 (permalink) Old 08-10-2011, 12:26 PM
Redfish-Joe's Avatar
For me I use the Dobeck EJK. Comes pre adjusted to what ever mods you have on your bike when you order it. Simple plug and play. Easy to tweak if need be. No computer, no dyno, no HD downloads. As far as the o2 sensors, just unplug them. Done. Tehy offer a very good discount to vets, fire and policemen.
Take a look and do some reading.
http://www.electronicjetkit.com/EFIcontrollers.asp
Redfish-Joe is offline
post #3 of 7 (permalink) Old 08-10-2011, 01:02 PM
Ditch's Avatar
I have power vision from fuel moto plug and play use stock o2 or you can add auto tune.
Sent from my PC36100 using Tapatalk
FOR THOSE WHO CAME HOME...
FOR THOSE WHO DID NOT COME HOME...
FOR THOSE WHO HAVE YET TO COME HOME...
1997 FXD(P) STOCKISH
1999 FXSTDC TO MODIFIED TO KEEP RUNNING
2011 FLRTU just starting the mods
Zummo 665
HD Air deflectors
Sancho's wings
Cee Bailey's 14in light tint
HD hammock seat heated
HD ajustable back rest
cup holder
Jackpot 2-1-2 with SE Fatshotz
Power Vision
Ditch is offline
post #4 of 7 (permalink) Old 08-10-2011, 02:31 PM Thread Starter
bvanlente's Avatar
Ditch from Power Vision:
There is only 1 wideband o2 sensor that works in our product line. It uses an M18x1.5 bung. You should be able to request to your exhaust manufacturer to preinstall this bung when you order the system. We understand that it might not be convenient to weld a bung into your exhaust pipe if you want to run auto-tune and your stock sensor size is not the same as ours, but this is just the way it is and I'm afraid there is no way around it except to just not use Auto-tune. You always have the option of having the bike tuned on a dyno.
Auto-tune gives the end user the capability to specify how rich or lean you want the bike to run, and because the device can see actual air/fuel ratio, via the Auto-tune wideband o2 sensors, it can self-adjust as you ride to get to your target air/fuel ratio, by populating a 2nd temporary fuel table called the trim table.
post #5 of 7 (permalink) Old 08-10-2011, 05:36 PM
I've been spending some time looking at all the options out there. I haven't bought anything yet, but when I do, I'm going to go with the Dobeck. Sure, I may be leaving some horses on the table because I won't have the "perfect" dyno-tuned map, but on the other hand, as you said - I won't be spending all that time (and money) on the dyno or replacing/updating maps all the time. It looks to me like it's the simplest and most straightforward answer out there. Also, once you unplug it, you're back to stock, just in case you need to deal with one of those pesky "warrantee" issues. From what I understand, tuners that change the maps can leave a fingerprint on the ECU, whereas the Dobeck just leverages the stock maps and adds fuel as necessary.
Al
Southern NH
2011 Road Glide Ultra
2005 Concours
mdwar2005 is offline
post #6 of 7 (permalink) Old 08-10-2011, 07:16 PM
I don't think you will be disappointed.
post #7 of 7 (permalink) Old 08-10-2011, 08:03 PM
DarbinCo's Avatar
For the reasons listed above like problems with maps, dyno tuning time and money, etc... I went with the thundermax w/at and never looked back. The bike runs so good, much cooler and way better two up.
DarbinCo is offline
Dyno tuner in Alabama - and what fuel management system justaguy ECM/Fuel Management systems 2 06-24-2013 10:23 AM
Fuel management wild1techguy ECM/Fuel Management systems 15 03-15-2013 05:19 PM
Cobra Fi2000 closed loop fuel management bt99ultra ECM/Fuel Management systems 16 02-04-2013 09:50 AM
Need to know about Fuel Management Devices Still Grumpy ECM/Fuel Management systems 11 11-02-2012 03:46 PM
fuel management options Tatude ECM/Fuel Management systems 12 09-22-2011 06:39 PM
