Rushmore T/P Adjustment - Road Glide Forums
  • 1 Post By wmiller959
post #1 of 7 (permalink) Old 11-17-2016, 01:27 PM Thread Starter
Q-Hog's Avatar
Is there any way to mount the Rushmore T/P further back?
Q-Hog is offline
post #2 of 7 (permalink) Old 11-17-2016, 02:10 PM
9over's Avatar
Sure there is a way. If it doesn't slide back far enough with the nuts loose you'll have to relocate the studs on the metal plate on the bottom of the T/P.
9over is offline
post #3 of 7 (permalink) Old 11-17-2016, 10:17 PM
BlazingSaddle's Avatar
Replaced tour-pak with a detachable tour-pak. Now less space between driver and passenger than original fixed rack. The removable tour-pak is adjusted as far back as possible on the new rack, yet still less space between driver and passenger. Wondering if docking kit points are adjustable or is it in a fixed position. Drilling out tour-pak to adjust further back not an option.
BlazingSaddle is offline
post #4 of 7 (permalink) Old 11-17-2016, 10:44 PM
wmiller959's Avatar
Search the site for the 'George Anderson Tour-Pak relocation kit', its a bolt on plate that moves the tour-pak back a couple of inches. I have one on my 2012 and my wife said it made a world of difference. Its a small business, you call him and he sends it out.
mastergunnera8 likes this.
2012 RGU
US Army 1978-1995
wmiller959 is offline
post #5 of 7 (permalink) Old 11-19-2016, 04:20 PM Thread Starter
Q-Hog's Avatar
Thanks fellas for the info. The Rushmore T/P removable mount does allows you to mount it an inch back.
Q-Hog is offline
post #6 of 7 (permalink) Old 11-19-2016, 06:38 PM
Smarty's Avatar
If that doesn't work, you can drill holes further back on the detachable mount, then take a 4" side grinder with a cut off wheel and finish the slots back to the new holes. Done this several times. No need to mess with the tour pak bolts.
2016 RGS Black Quartz
Smarty is offline
post #7 of 7 (permalink) Old 11-22-2016, 12:03 PM Thread Starter
Q-Hog's Avatar
Thanks Smarty. Good idea.
Q-Hog is offline
Rushmore Fairing Lowers vs. Pre-Rushmore The Volusianator Paint & Bodywork Section 9 07-23-2018 10:47 AM
Rushmore Handlebar Adjustment KevDillow Do-IT-Yourself 13 05-04-2017 09:01 AM
Biggest Rushmore Improvement Over Pre-Rushmore Bikes??? 09Sharknose *General Road Glide Discussions/Pictures 15 02-14-2016 08:31 AM
Rushmore bars on pre Rushmore bikes Steelerdude1 *General Road Glide Discussions/Pictures 1 11-08-2015 03:02 PM
No Rushmore RGs at Rushmore Buiceman *General Road Glide Discussions/Pictures 25 07-04-2015 09:29 AM
