Anyone else have trouble removing backrest - Road Glide Forums
  • 1 Post By SteadyEddie
post #1 of 6 (permalink) Old 10-02-2018, 08:17 AM Thread Starter
I took my passenger backrest off and the right side seemed impossible, I actually had to tap the clamp with a hammer (rubber dead blow hammer) to get it to move both on and off. The left side popped right off with minimal effort. My buddy has a 15 RG and he said he has the same problem.
2018 Road Glide Special
upsydown is offline
post #2 of 6 (permalink) Old 10-02-2018, 08:42 AM
SteadyEddie's Avatar
Check the Mounting Piece that the Backrest locks into - It will fit ON backwards but will be a BITCH to "Click" the backrest into place - Try turning the piece around and refastening it.......worked for me on my old '15
ksbutler44 likes this.
SteadyEddie is offline
post #3 of 6 (permalink) Old 10-02-2018, 08:47 AM
Easy fix.. The lugs on your docking hardware are not perfectly round, they are slightly oblongated. You need to loosen up the torx screws holding the mounting points and index your quick detach stuff to it. In other words, slowly spin the mounting points until they fit correctly and then tighten up. They points are made to have a little bit of adjustability in them. I believe it is covered in the docking hardware installation pamphlet. I had the same issue on my 2018 and had never had the issue before and was unaware that they were oblong until I read the specs. Funny how that happens.
2012 RG Vivid Black- Old Friend
2018 RG Special Bonneville Salt Pearl- New Friend
2003 100th Anniversary Heritage Springer- Real Old Friend
JadaGlide is offline
post #4 of 6 (permalink) Old 10-02-2018, 08:55 AM
See below from install directions:
post #5 of 6 (permalink) Old 10-02-2018, 10:07 AM
Thermodyne's Avatar
Put a little dry silicone lube on the mounts.
Thermodyne is offline
post #6 of 6 (permalink) Old 10-02-2018, 10:59 AM
UT_Larry's Avatar
15 RGS is one of the shocks inverted? If it is it is a known issue to cause trouble with the passengers back rest. The shock can be flipped to resolve the issue.
UT_Larry is offline
What else do you have in the garage djfoster83 *General Road Glide Discussions/Pictures 162 12-14-2018 06:20 PM
Anyone Else have this Road Glide Poster? twowheeladdict *General Road Glide Discussions/Pictures 17 07-10-2017 10:23 AM
Anyone else have check engine light pipe3214 Audio 5 06-22-2014 07:51 PM
Removing Trap Door without removing Exhaust kevanbo Do-IT-Yourself 7 04-03-2014 06:01 PM
Anyone else have trouble fueling up? Bluefilhd *General Road Glide Discussions/Pictures 26 06-30-2013 10:31 AM
