Quick Release Tour Pack - Road Glide Forums
  • 1 Post By BigBlockBobby
post #1 of 3 (permalink) Old 04-06-2019, 06:58 AM Thread Starter
Emil1's Avatar
I installed a HD quick release tour pack on my 2017 RGU. I mostly love it. Its like having two bikes in one.
I have one problem that I'm hoping you folks can help me solve. The original TP mounting base is two levels. One of the levels has little holes that the wiring harnesses are attached to. The quick release base only has one level and no where to secure the wiring harnesses. The first time I rode with the TP, the harnesses left a small scratch in the fender's clear coat.
Since then, I wrap the harnesses and they lay on the fender. It's inconvenient to wrap them each time. Any ideas would be welcome.
Pictures of the two bases are attached.
Thanks
Emil
Emil1 is offline
post #2 of 3 (permalink) Old 04-06-2019, 10:20 AM
BigBlockBobby's Avatar
My first thought is "if" you have enough slack in the harness drill a small hole in the QD rack and add a harness clip. Something like this. https://www.ebay.com/itm/10x-electri...-/282264154513
Or if you need some more slack you could use one of these and just leave it loose enough to pull the wiring connector though it.
James likes this.
BigBlockBobby is offline
post #3 of 3 (permalink) Old 04-06-2019, 08:46 PM
Thermodyne's Avatar
Would velcro tape work?
It would make accessing the harness easy. 3M makes some real industrial strength tape. I use it to hold the radar detector on mine.
Thermodyne is offline
Tour pack adjustment kit BklynRGU Aftermarket Accessories 15 10-03-2015 12:08 PM
WTB tour Pak with quick release hardware Matt11FLTRX Wanted! (Buy or Trade) 0 04-12-2015 10:35 AM
Quick release tour pak GliderRider *General Road Glide Discussions/Pictures 5 11-24-2013 09:45 PM
Quick detachable tour pack mount jokercraze Sold 3 08-23-2012 09:30 AM
Tour Pack Adjustment Kit BklynRGU Seating: seats, backrests 11 02-05-2012 08:31 PM
