Zumo 660 Hardwire - Road Glide Forums
post #1 of 5 (permalink) Old 03-06-2014, 10:24 AM Thread Starter
CSM11's Avatar
Zumo 660 Hardwire
Since the weather is finally getting nice I'm going to install my GPS, my question is can I wire it to my accessory plug under the seat? If so what is the part number for the connector to wire it, thanks
CSM11 is offline
post #2 of 5 (permalink) Old 03-06-2014, 10:19 PM
perrykw's Avatar
I ran mine straight to the main fuse panel. There is a spot for it, you just need to look up the install directions for the handlebar mount and it will give you the part number for the adapter wire to install directly to the fusepanel. If you do want to use the accessory connector, the dealer should have the plug. I went to my local dealer and told them I needed the opposite side of the plug and the service manager took care of me. If you want to order from the internet, I have ordered Deutch connectors from wireccare.com. It's a 4 pin Deutch DT Connector
perrykw is offline
post #3 of 5 (permalink) Old 03-07-2014, 06:55 AM
Smile
Or just wire it to the cigarette lighter wires. Much easier to get to.
pilot is offline
post #4 of 5 (permalink) Old 03-07-2014, 09:49 PM
same here, the lead to install into the fuse block came in the install kit...it works off the ignition lock
ricerocketroaster is offline
post #5 of 5 (permalink) Old 03-08-2014, 08:07 AM
I just ran a wire with a quick disconnect from the cig lighter up behind the speedo when Paul was swapping out my fairing. The quick disconnect will suit me well as I don't want a mount on my bike all the time for the GPS. TouraTech sells them for like $12.
BigWaterJim is offline
Garmin Zumo 660 RT wired up..... SEUGOT1 Aftermarket Accessories 10 04-03-2012 10:15 PM
Garmin Zumo 660/665 GPS Locking Mount HarleyCharley Equipment-RG 9 01-09-2012 07:50 PM
2011 RG CVO Zumo 660 Phone Intergration stewarrd Troubleshooting for Road Glides 26 06-18-2011 10:48 PM
Zumo 660 plumcrazeman Aftermarket Accessories 0 12-27-2009 10:49 AM
