Zumo hardwiring - Road Glide Forums
post #1 of 8 (permalink) Old 01-01-2015, 07:57 PM Thread Starter
Zumo hardwiring
Installing GPS on Roadglide. Instructions talk about hardwiring into fuse panel. Is there an easier way to go under fairing. Lighter not option already taped in for satelite radio. Saw wire with cap on called HDI only in wiring diagram. Anybody know if that works.
Houseman is offline
post #2 of 8 (permalink) Old 01-01-2015, 08:11 PM
perrykw's Avatar
I wired mine to the fuse panel. It was a pain, but worth it in the end because of the clean install. Running the wiring was easy. Adding the circuit to the fuse panel was a pain but doable with the included directions. Just take plenty of breaks so you don't go after it with a BFH LOL
perrykw is offline
post #3 of 8 (permalink) Old 01-01-2015, 09:45 PM
skratch's Avatar
what year? i wired mine direct to the battery and ran the wire up through the wiring channel (removed the fuel tank). was pretty easy and no extra wires running anywhere.
skratch is offline
post #4 of 8 (permalink) Old 01-02-2015, 07:02 AM
Smile
You can wire it directly to the cigarette lighter. The GPS does not use much power even with the Sat Radio already wired to it your still good to go.
[email protected]
pilot is offline
post #5 of 8 (permalink) Old 01-02-2015, 09:06 AM
Ohiobellboy's Avatar
There's always that extra wire in the headlight harness you should be able to use also if the power is not much draw. Should be hanging out on the throttle side of the harness in the fairing.
A.K.A OBB
Ohiobellboy is offline
post #6 of 8 (permalink) Old 01-02-2015, 02:57 PM
dnschmpn's Avatar
I have mine wired to the lighter and have had no issues in 6 years.
Enjoy the Ride!
2013 RGU in Big Blue Pearl
dnschmpn is offline
post #7 of 8 (permalink) Old 01-02-2015, 07:27 PM
I used a kit from touratech, so I can quick disconnect if I want. Wired to cig lighter where I also taped in for a usb charger in glove box. No issues.
BigWaterJim is offline
post #8 of 8 (permalink) Old 01-03-2015, 06:43 PM
I also wired my Garmin Zumo 550 then updated to a 665LM to the headlight harness without issue.
HoMa506 is offline
Garmin Zumo 550 Install brightonrider GPS 14 11-27-2013 01:20 PM
Zumo and Cigarette Lighter mtatl *General Road Glide Discussions/Pictures 10 09-29-2010 01:47 PM
HD Zumo 665 GPS longrides Aftermarket Accessories 8 09-01-2010 10:29 PM
Garmin Zumo Question RoadGlide0611 *General Road Glide Discussions/Pictures 0 08-10-2010 05:53 PM
Zumo 660 plumcrazeman Aftermarket Accessories 0 12-27-2009 09:49 AM
