Road Tech Zumo 665 Installation - Road Glide Forums
post #1 of 12 (permalink) Old 01-29-2015, 07:54 PM Thread Starter
Ernster500's Avatar
Alright, Guys,
I think I am going to spring for the Road Tech Zumo 665 and mount it with the Iron Aces mount.
Trying to piece all the info together for what I need to install it on my 2012 Road Glide Custom, and scouring through the posts is proving to be a little more difficult that I anticipated.
So, what exactly do I need for the perfect clean install?
Obviously, I need the GPS (p/n 76000014A). What else do I need from HD?
Thanks!
E
2012 Big Blue Pearl FLTRX
Ernster500 is offline
post #2 of 12 (permalink) Old 01-29-2015, 08:01 PM
Mike U's Avatar
I mounted mine with the Iron Aces Mount and it was pretty straight forward.
I wired mine to the accessory switch and ride with it on all the time.
The XM works great through blue tooth also.
If I can be of any assistance feel free to PM me.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #3 of 12 (permalink) Old 01-29-2015, 08:19 PM
Ohiobellboy's Avatar
There's one for sale in the classifieds also.
A.K.A OBB
Ohiobellboy is offline
post #4 of 12 (permalink) Old 01-29-2015, 08:34 PM
perrykw's Avatar
I wired mine to the main fuse panel. It was a bit of a pain, but ended up being a clean install.
perrykw is offline
post #5 of 12 (permalink) Old 01-29-2015, 10:13 PM
cobra206's Avatar
+1... I did the same thing
cobra206 is offline
post #6 of 12 (permalink) Old 01-29-2015, 11:53 PM
Phantom6722's Avatar
+1 did the same thing; there is a 2 amp fuse in the fuse box just for a GPS. Real easy to take the tank off and run your wiring down through the centre ducting.
Cheers Skip
Phantom6722 is offline
post #7 of 12 (permalink) Old 01-30-2015, 07:31 AM
Ran mine to the cig lighter in the fairing. I used a quick disconnect behind my speedo so I can take the garmine mount off and hook up a USB and moun phone when not on trips.
Get a Kradlelock for peace on mind also. Here's a pic of my mount.
BigWaterJim is offline
post #8 of 12 (permalink) Old 01-30-2015, 08:02 AM
Post
Here is a video showing one way to install the GPS. It also shows how to install the HD Bomm for those who want to make and take phone calls via the Bluetooth link with the GPS. You don't need the HD Bomm unless you want this function.
https://www.youtube.com/watch?v=yYE-...ature=youtu.be
If you are using a Bluetooth helmet then all you need to do is connect power and the XM Puck and your done. If your using a wired headset then you will need to install the audio output from the GPS to the Auxiliary input on the front of the radio. You will need a 3.5mm Male Stereo to 3.5mm Male Stereo cable to accomplish this. Radio Shack P/N 42-223. Remember in order to hear any turn prompts your radio must be in the AUX mode.
If you don't like the looks of the cable plugged into the AUX port you can modify the radio to add an Auxiliary Input to the back of the radio. You can find the complete directions to do this on the HD Bomm web site.
If you want full integration for the turn prompts then you will need to buy the Harley branded Zumo, the Road Tech 660 or 665 but you will also need to buy the Harley Navigation Interface Module (NIM). you can find more information on the NIM and how it works on the HD Bomm web site.
Jim
pilot is offline
post #9 of 12 (permalink) Old 02-09-2015, 12:31 PM Thread Starter
Ernster500's Avatar
Thanks for the info, guys. Greatly appreciated.
Is there any advantage to connecting power to the fuse box as opposed to the lighter or the auxiliary connector?
Why go one way or the other?
Seems the lighter way might be the easiest to do. Any reason not to?
post #10 of 12 (permalink) Old 02-09-2015, 12:48 PM
Bull_Duck's Avatar
When I had my front fairing off, I connected my power cord to the back side of the cigar lighter. The power cord was routed through a hole I drilled in the back of the left cubby, above the lighter. I don't use a Zumo, instead an iPhone connected via Bluetooth. When the iPhone is connected, it is on the Ram Mount. When off, the power cord tucks into the cubby. You can see the Ram Mount in the attachment.
Bull_Duck is offline
Road Tech Zumo 665 wiring questions Govdog76 GPS 10 05-20-2013 08:48 PM
Road Tech Zumo 665 longrides Parts for Sale 4 05-01-2013 04:32 PM
Road Tech Zumo 665 longrides Sold 0 05-01-2013 12:40 PM
Road Tech Zumo 665 - Wiring bootlegger61 Equipment-RG 5 03-19-2013 12:02 PM
Notes on the Road Tech zumo 665 Dhambrick Equipment-RG 12 07-27-2012 05:11 PM
