GPS Mount - Road Glide Forums
post #1 of 18 (permalink) Old 07-24-2012, 07:26 PM Thread Starter
BlackDangerous's Avatar
GPS Mount
I have finally found a GPS mount that seems that it will work the way that I want it to. Now my question is how do you guys plug yours in? Do you have it hardwired to the accessory switch or do you just plug it into the lighter each time?
I am not using a Zumo, just a regular ol' Garmin Nuvii... Thanks...
BlackDangerous is offline
post #2 of 18 (permalink) Old 07-24-2012, 08:20 PM
I have my Garmin nuvi hard wired to the accessory plug under the seat.
It really isn't too bad of job to take the tank off and do it right.
2012 FLTRX
bad86ta is offline
post #3 of 18 (permalink) Old 07-25-2012, 09:37 AM
ameleo's Avatar
Hard wired mine to the wires from the accessory switch behind the speedo/tach. Hang the power wire through the clip that supports the clutch cable. I use the accessory switch to turn off the power if the unit is unplugged.
ameleo is offline
post #4 of 18 (permalink) Old 07-25-2012, 10:13 AM
TLWiz's Avatar
I plug my TomTom (mounted on a RAM mount on the left mirror mount) into the lighter plug with a short coiled powercord that doesn't get in the way but has no trouble with handlebar movement. I only use the GPS on long trips and I like to be able to remove it easily and lock it up when parked.
TLWiz is offline
post #5 of 18 (permalink) Old 07-25-2012, 03:24 PM Thread Starter
Thanks for the information. Now I am curious that when I do this, will I be able to hear the "bitch in the box" through my speakers or is this going to require some different type of wiring? Thanks....
post #6 of 18 (permalink) Old 07-25-2012, 05:18 PM
FLTR2008Trike's Avatar
I purchased one of these for my Garmin Nuvi>>> http://www.ebay.com/itm/GA-NHWC2-Gar...#ht_973wt_1160
Im going to install it under the fairing this weekend
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #7 of 18 (permalink) Old 07-25-2012, 05:24 PM
Double post, sorry
post #8 of 18 (permalink) Old 07-25-2012, 05:34 PM Thread Starter
this is what I was looking for and could not find!!! Thanks a Billion!!!
post #9 of 18 (permalink) Old 08-13-2012, 07:26 PM
Did you get this wired up yet? Curious how you like it?
Thanks!
ramdonkey is offline
post #10 of 18 (permalink) Old 08-13-2012, 10:06 PM
I pulled the fairing apart and hard wired an adapter to the lighter wiring. When the bike is turned on, the Garmin sees power available and when it is turned off it asks whether I would like to continue running on internal batteries. In my case the adapter really lives in one glove box and only the wiring connection is inside the fairing. It seemed like a good answer to me with my Garmin mounted to my windshield. With as much fun as I had pulling and re-installing the fairing, make sure you get it right on the first go. You don't want to find out after everything is back together that something is not working right.
Added equipment was a stage 1 HD air cleaner, a Cee Baileys windshield and a turn out boot heel guard. I also went with the BAL1 tail light MOD. You can never be too safe with lighting. Now I am riding a Vision with minor mods to give me this.
Oldman47 is offline
Anybody using a regular GPS in their bike? Not a motorcycle specific GPS twincam103b Do-IT-Yourself 21 06-07-2018 05:22 PM
Normal GPS vs Motorcycle GPS dinggus GPS 23 06-07-2017 02:39 PM
Smartphone mount besides my Iron Aces GPS mount SEUGOT1 Audio 12 01-05-2014 07:33 PM
GPS mount for handlebar Livennjoy Aftermarket Accessories 38 11-29-2010 02:11 PM
