Gps install - Road Glide Forums
post #1 of 12 (permalink) Old 07-26-2012, 04:40 PM Thread Starter
Jettjocky's Avatar
Gps install
Sorry I could not find where some one was asking how others installed their GPS. See pics attached this is a chrome RAM 1 1/2 arm. I wanted the unit low not high up on the bars. anyway sorry for delay, again could not find the original request.
09 O/B CVO....Roller rocker arms, 10.5 pistons, HQ 575 Cams, SE adjustable push rods, Cee B., Rineharts, Mustang, Progressive front & rear, Moto Lights, HD LED Headlights, C & C Seat, Avon Grips,
HOGCOVERS
Jettjocky is offline
post #2 of 12 (permalink) Old 07-26-2012, 04:41 PM Thread Starter
Jettjocky's Avatar
low but can be seen
HOGCOVERS
post #3 of 12 (permalink) Old 07-27-2012, 09:33 PM
Phantom6722's Avatar
Here's what I did three days ago to install my Zumo 660
Cheers Skip
Phantom6722 is offline
post #4 of 12 (permalink) Old 07-27-2012, 09:37 PM
Side cuts point to GPS power lead. Second shot of loop under fairing for H-Bar full movement.
File Type: jpg GPS Wire Loop for H-Bar full Movement.jpg (89.6 KB, 121 views)
Cheers Skip
post #5 of 12 (permalink) Old 07-27-2012, 09:39 PM
Shows redundant wiring turned back into cable tray.
File Type: jpg Redundant wiring Turned back into cable tray.jpg (97.7 KB, 82 views)
Cheers Skip
post #6 of 12 (permalink) Old 07-27-2012, 09:41 PM
Tank removed and wiring harness opened up to run GPS power lead to fuse box.
Cheers Skip
post #7 of 12 (permalink) Old 07-27-2012, 10:29 PM
magnamover's Avatar
Why would you do this? I added a power point in the left side glove box and plug my GPS into that. I have a $10 handlebar mount from ebay.
I did run a new power lead for my HIDs but that was necessary for clean uninterrupted power.
2010 RGC BLK, ABS, cruise, SE 110, D&D, SERT, Zippers AC, Removable tourpak, Heated hammock seat, plasma rods, Hogtunes 5x7 speakers, 14.5" Madstad, rider's backrest, Daymakers, heated grips. Skip the GADS.
magnamover is offline
post #8 of 12 (permalink) Old 07-28-2012, 03:42 PM
Don’t like to use light outlets for powering devices, too much trouble once the lighter plug or socket start to wear due to vibration. I took it to the fuse box because there is a 2 amp spare fuse for the GPS. The GPS turns on automatically when I turn on the ignition switch to ignition or auxiliary. Taking the tank off is really easy (see thread in “do-it –yourself’ with pictures). What’s HID’s? Something contagious?
Cheers Skip
post #9 of 12 (permalink) Old 07-29-2012, 12:25 AM
BlackDangerous's Avatar
Thanks gentleman, It is possible that this thread was intended for me. I like the idea of wiring it to the fuse box better as well. Thanks for the pictures..
BlackDangerous is offline
post #10 of 12 (permalink) Old 07-30-2012, 12:46 PM
magnamover's Avatar
HID is that newfangled thing that came out in 1992. It is true that taking of the tank is easy, but it is much easier to tap off the wiring on the fairing mounted power point to hard wire items. It is also only powered when ignition is on.
Anybody using a regular GPS in their bike? Not a motorcycle specific GPS twincam103b Do-IT-Yourself 21 06-07-2018 04:22 PM
Normal GPS vs Motorcycle GPS dinggus GPS 23 06-07-2017 01:39 PM
Zumo GPS Install? TKGlide *General Road Glide Discussions/Pictures 19 01-07-2015 01:54 PM
Daymaker Light Install - Install Problem - And Resolution Martin Lighting 22 06-06-2013 07:57 PM
GPS Install HUTMO Aftermarket Accessories 21 07-28-2010 09:22 PM
