Wiring my GPS - Road Glide Forums
post #1 of 13 (permalink) Old 05-04-2015, 11:40 AM Thread Starter
Wiring my GPS
I have a 2013 Road Guild Ultra. I would like to hard wire Garmin Zumo 550
to the ACC switch. Need any and all advise or ideal's Thanks
lardog is offline
post #2 of 13 (permalink) Old 05-04-2015, 01:55 PM
wjco9's Avatar
If you get the lighter kit that's for the road king it comes with the plug for the accessory plug under the seat, then crimp on the connectors on your gps write and plug it in
Live to Ride
Ride to Eat
wjco9 is offline
post #3 of 13 (permalink) Old 05-04-2015, 02:06 PM
sfcusaret2004's Avatar
Harley sells an install kit for the zumo that incorporates it into the wiring harness and works with the sound system and hand controls. Why not use that?
sfcusaret2004 is offline
post #4 of 13 (permalink) Old 05-04-2015, 02:52 PM
wjco9's Avatar
My understanding is the harley harness only works on the roadtech not the straight zumo
Live to Ride
Ride to Eat
wjco9 is offline
post #5 of 13 (permalink) Old 05-04-2015, 03:12 PM
OKBigD's Avatar
order the plug for under the seat from Iron Aces, then order the Garmin Hard wire kit from Amazon, and run it along the backbone under the tank. Then you can choose to have it either power on with the bike ignition or via the accessory switch..
http://www.ironacesspeedshop.com/sup...v-power-point/
OKBigD is offline
post #6 of 13 (permalink) Old 05-04-2015, 03:15 PM
PGR
PGR's Avatar
Agree with what the others have said...... and Welcome to the forum.
Ron..........................
PGR is offline
post #7 of 13 (permalink) Old 05-04-2015, 07:19 PM
HUTMO's Avatar
gps install
I went with the CVO GPS mount. It goes right onto the control on the left hand side of the handle bars.
As for wiring it I would use the accessory wire that Harley come with. It it's the grey plug down by the battery. Run the wire under the tank and then up along the cable that goes for the controls on the left hand side. That way, if you unplug the GPS you could turn the plug off using the accessory switch.
Good luck
Hutmo
HUTMO is offline
post #8 of 13 (permalink) Old 05-07-2015, 02:03 PM
MidNightRGU's Avatar
Since I very rarely use the fairing lighter, I routed the lead across to the fairing and wired into the lighter. I have a lighter in the trunk for charging phones, etc. When ignition is turned off, the GPS will give you 30 seconds to keep it on, or by default it will turn off. Fishing the wires under the tank has always been a headache and the Mrs. requires heated gear under 40 degrees. So I save the accessory outlet. When there is a problem with the wiring, there will be less connections to trace...
BTW, I used a RAM mount for the GPS, it sits higher, doesn't block other gauges.
MidNightRGU is offline
post #9 of 13 (permalink) Old 05-11-2015, 12:55 PM
Amazon.com: EDO Tech® Direct 12V Hardwire Car Mount Charger Cable Adapter Kit for Garmin Nuvi Zumo Streetpilot GPS: GPS & Navigation
+1..I've got a 2011 RGU and use the Iron Aces Mount and hardwired my Garmin 660 direct to my battery. Removing the tank was a breeze and the Iron Aces Mount puts the Garmin right in front of you.
Minivend is offline
post #10 of 13 (permalink) Old 05-28-2015, 01:42 PM
seetiggergo's Avatar
Thanks for the shout-out guys...we've had a lot of folks go with our 12v Power Point when wiring up their GPS units. It's a great solution especially if you want to be able to turn power to the unit on / off.
As mentioned, the biggest hang-up people have going this direction is removing the tank but if one can remove four bolts, disconnect a quick-release valve and lift 10lbs then there shouldn't be any concern...in reality, the job including soldering the GPS power cable to our 12v Power Point, can all be done in roughly an hour start-to-finish.
Hope this helps!!
Lindsey :0)
'08 Harley Road Glide - Iron Aces Mount - Too many other upgrades to list!
seetiggergo is offline
Anybody using a regular GPS in their bike? Not a motorcycle specific GPS twincam103b Do-IT-Yourself 21 06-07-2018 05:22 PM
Normal GPS vs Motorcycle GPS dinggus GPS 23 06-07-2017 02:39 PM
Wiring a GPS ButchS Aftermarket Accessories 14 08-27-2013 07:07 PM
Wiring GPS Maxcustody Road Glide Specific Discussions 20 02-21-2012 11:19 PM
GPS wiring Jake6470 Aftermarket Accessories 5 06-23-2011 06:47 PM
