garmin gps - Road Glide Forums
post #1 of 3 (permalink) Old 08-16-2012, 05:51 PM Thread Starter
garmin gps
I have a delema the Garmin GPS device is missing off my bike. Shouldnt have left it in front of starbucks to long.
So I do have a 2011 Road Glide screaming eagle ultra this was a factory equip/installed the base is there just the unit is missing. The question that I do have is there other model that I can use with this base. And what is the model # for this Garmin device.
Thanks
E9 Turbo
e9turbo is offline
post #2 of 3 (permalink) Old 08-16-2012, 08:25 PM
fltreagle's Avatar
There is a couple of questions, which unit did you have, A HD Road Tech Garmin or a Garmin Zumo? The Garmin 665 has xm capabilities, while the 660 does not, so do you have a xm antenna on the bike? While the mount is the same the functions of the mounts are different. If you have the harley mount you can use either the HD version or the Garmin unit. That is the limit of what will work in the mount you currently have.
fltreagle is offline
post #3 of 3 (permalink) Old 08-26-2012, 09:00 AM
Phantom6722's Avatar
Garmin 660 should plug straight in.
Cheers Skip
Phantom6722 is offline
J&M headset amp w/ Garmin GPS mount coryo Classifieds Archive (3 months old+) 2 05-13-2012 05:11 PM
Garmin Zumo 660/665 GPS Locking Mount HarleyCharley Equipment-RG 9 01-09-2012 06:50 PM
My Garmin 4x3 GPS mounting solution Lama Aftermarket Accessories 35 09-09-2011 11:31 AM
Garmin 2730 gps HUTMO Classifieds Archive (3 months old+) 0 03-15-2011 07:05 PM
