Garmin Zumo 550 Install - Road Glide Forums
post #1 of 15 (permalink) Old 09-06-2010, 02:59 PM Thread Starter
brightonrider's Avatar
Just bought a new Garmin Zumo 550 GPS.
Thought I could power it with the cigarette lighter like I did with my Nuvi.
Turns out the adapter that comes with it only works in the automobile mount...bummer!
Any way to get around this?
If not what's the easiest way to wire it up...I'm not too mechanically competent.
Thanks.
RonC
brightonrider is offline
post #2 of 15 (permalink) Old 09-06-2010, 07:18 PM
dklanecky's Avatar
Nuvi 550
I had a similar issue with my Nuvi 550, I could power my cigarette lighter element from the lighter plug, but not the Nuvi or the Satellite Radio either.
I asked the dealer why it wouldn't work. They took the fairing off and switched the wires on the back of the lighter plug, and now everything works from the lighter plug.
Apparently the lighter element doesn't care about polarity but everything else does.
73 Sporty - Sold
07 Sporty - Sold
09 Vivid Black Road Glide (FLTR) with ABS, Security, Fuelmoto Satge One, Clearview, Harley Hammock Seat, Hogg Chopps Lowers, Bright Ass Tail Light, SERG Headlight Bezel, Detachable King Tour Pak, Painted Inner Fairing, Cruising Southeasten Wisconsin, Delivered 3/6/2009:clap:
09 Black Fat Bob (FXDF) in Vivid Black of course, Delivered 5/1/2009
dklanecky is offline
post #3 of 15 (permalink) Old 09-07-2010, 07:57 PM
Use the cable that comes with the 550 and an adapter from Harley that connects to the spare accessory connector under the seat in front of the battery. Doing this allows the power to turn on and off via the accessory switch on the dash. It's not too hard to do.
Harley Part number is 91843-97
cincyMAT is offline
post #4 of 15 (permalink) Old 09-07-2010, 08:35 PM
RoadGlideRider's Avatar
What is the difference between the 550 and the 650? (Or even the 600?)
RoadGlideRider is offline
post #5 of 15 (permalink) Old 09-08-2010, 06:44 AM
dklanecky's Avatar
This part number is just an extra accessory lighter socket, right? I hard wired my Nuvi 550 directly to the back side of the stock cigarette lighter using butt slices and shrink tubing. Very easy to do, and provides a nice solid connection, while the lighter plug is still available on the outside of the fairing. The step down voltage box is just siliconed to the upper part of the inside fairing,plenty of room up in there on the sides.
73 Sporty - Sold
07 Sporty - Sold
post #6 of 15 (permalink) Old 09-08-2010, 06:47 AM
dklanecky's Avatar
Mostly price, but there is a significant tradeoff in features. The Nuvi 550 has a price of about $260. The 500-550 were some fo the original Nuvi's that work on motorcycles,and were flagged in the Garmin Product list as "motorcycle friendly" meaning primarily waterproof,and have the ability to sort multiple destinations. I like mine a lot.especially for the cost.
73 Sporty - Sold
07 Sporty - Sold
post #7 of 15 (permalink) Old 09-08-2010, 07:46 AM
That's right, I didn't use the lighter socket part of the kit. Just the connector and wires. I like being able to shut it off via the accessory switch. The step down transformer can fit in the plastic wire way under the fuel tank.
Mark
09 FLTR
cincyMAT is offline
post #8 of 15 (permalink) Old 09-09-2010, 03:38 PM
FLTRI's Avatar
I wired mine right to the empty hot and ground wire near the headlight wires. It's there for the international bikes, I think. It's switched with the ignition. Hot when running and accessory, off when well, off... All I had to do was put a couple of spade connectors on the Garmin wiring harness. Quick. Simple, easily removable and no cutting or splicing of the factory wires.
The hardest part is wrestling the fairing back on. The easiest way is to pull the headlamp assembly, put the fairing on, and snap in the headlamps. Pretty common trick for a Road Glide...
You're gonna love it, BTW. It's a great GPS!
I hate that motorcycle they make me ride. I'm here to tell you there ain't nothing in the world I hate worse than that elephant under my ass.
Officer John Wintergreen reference his Electra Glide.
-Electra Glide in Blue, 1973-
FLTRI is offline
post #9 of 15 (permalink) Old 09-14-2010, 06:17 PM
Wes10RG's Avatar
Thanks.
RonC
I bought a Nuvi and have only had it on my bike one or two times and it's found a happy home in my car. Been thinking about getting a Zumo for the bike, how do you like it vs the Nuvi?
Wes10RG is offline
post #10 of 15 (permalink) Old 11-26-2013, 08:55 PM
THANK YOU! Out of all the different ways I've been reading about how to wire this up THIS was the easiest. I saw the big red plastic cap next to a black wire. I took a hot wire probe to confirm, rough wired it for a function check and everything was good to go. Sealed the job with the spade connectors and shrink tubing then reinstalled the fairing.
HoMa506 is offline
FS: Garmin Nuvi 550 GPS and accessories Lu Parts for Sale 1 08-07-2017 12:40 PM
GArmin Zumo 550 k9shag GPS 0 10-08-2012 10:02 PM
Garmin Zumo 550 - complete! pratt733 Miscellaneous for Sale 9 12-09-2011 09:43 AM
HK Radio & Zumo 550 Rippest Aftermarket Accessories 16 05-31-2011 05:26 PM
